Old 05-11-2012, 03:31 AM   #1
casrak7
Liked 3 Times in 2 Posts
Default et difference between............?
steel wheels (15x8 rear, 15x7 fronts), and Draglite style wheels, (15x8 rear and 15x4 fronts). Is .05 reasonable to expect from that loss in rotating mass?
casrak7 is offline   Reply With Quote
Old 05-11-2012, 03:36 AM   #2
casrak7
Default Re: et difference between............?
Im sorry....Im sure alot of this depends on the current et of the car in question......Currently low 11's at close to 118. 3150 w driver and the steel wheels. 350 chevy w cast crank and junk PM rods, 10-1 compression, 251/258@.050 solid flat tappet, .582/.560 on a 105lsa. Older mildly warmed up brodix -8 heads, holley strip dominator intake manifold, junk 1 5/8 headers with a couple smashed tubes, 4 feet of 3" pipe with 2 chamber mufflers, 820 cfm holley, 4.88 gears, 28x10.5 m/t slicks, 5300 8" tci converter, 36 degrees locked, shifts at 7000, crosses at 7100.
Old 05-11-2012, 06:10 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I'm going to say, yes....
Old 05-11-2012, 06:55 AM   #4
GTX JOHN
Liked 2,490 Times in 700 Posts
Easy...... Car will be about 25 - 30 lighter as well as rotating improvement.
Old 05-11-2012, 08:48 AM   #5
tj310
I use a rule of thumb of 2 to 1 for rolling mass vs stationary in drag racing . Racing where you have to start and stop is more sensitive to changes in rolling mass . I predict some one will tell you it's 10 to 1 and your car will go so fast you'll have to add a chute. ---Trevor
