#11 | |
Liked 5,121 Times in 1,952 Posts
#12 | |
Liked 13 Times in 11 Posts
But I'm not a bracket racer by nature "at all". I figure class racers may have some useful info though , if anyone would know if its not a good design , they would. |
#13 |
Joe you also have to run a remote oil filter with them because you cant get at the oil filter with the flat collector. just one more draw-back to that style......sorry.
#14 | |
Using a K&N HP2002 |
#15 |
Not true, although you will make a mess all over the headers changing it.
Chad Rhodes 2113 I/SA |
#16 |
Liked 46 Times in 29 Posts
lay a pig mat over the headers before dropping the filter. I finally started doing it since I got my regular headers coated.
#17 |
This may seem a little irrelevant to some, but the VW Formula Vee guys have debated flat style 4-1 versus the more traditional square 4-1 collectors for a long time. Those guys run old, stock, small port single carb engines that have been tweaked by some pretty bright guys since the 1960's. At 50-some-odd hp output, they'd give their eye teeth for 3hp. Since you don't see one style or the other exclusively in use, my guess is there isn't a lot to be lost, or gained, if the rest of the header has been sized and constructed right.
