Old 03-23-2012, 04:26 PM   #1
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Tri Y vs. Conventional Header....
Has anyone seen any advantage with a Tri Y over a Standard header in a stocker setup, WITH THE SAME CAM? I run a modified set of Lemon's Headers and want to explore a little on the topic. I know some have shown better numbers after a cam swap, but it seems to take several tries to make a small gain. Not dis-satisfied with what I have, just pecking......
Wade O
Old 03-23-2012, 08:01 PM   #2
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: Tri Y vs. Conventional Header....
Wade,
I wouldn't be dis-satisfied with the way your car runs either. I was at Indy last year when you were running class and I swear the headers were spitting HP.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 03-23-2012, 10:57 PM   #3
REGGIE WINKLES
Liked 39 Times in 9 Posts
Wade get in touch with Bill Grubb, he had those tri-y's on Brenda's car when it had the small block program. He'll tell you straight. I have a set on my stick car but, haven't been out yet. Jury's out........
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 03-24-2012, 08:11 AM   #4
Mike Fuller
Liked 198 Times in 79 Posts
I bought a set of Elston,s Tri Y's and didn't change anything else and saw about eight hundreth's.
Mike Fuller 396 STK
3961 SS
Mike Fuller is online now   Reply With Quote
Old 03-24-2012, 08:45 AM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Flowmaster's 4-2-1 Scavenger collectors were worth 8 hundreths on my 468 BBC running a 1 3/4" primary tube header.
Old 03-24-2012, 09:09 AM   #6
Bill Grubbs
Liked 564 Times in 66 Posts
Wade,
Beautiful car!!! I wanted to say hi at BR, but could not find time.
Anyway, to answer your question (it is at the bottom of the page) ----> http://www.popularhotrodding.com/tec...ech/index.html
Bill Grubbs
Bill Grubbs is offline   Reply With Quote
Old 03-24-2012, 12:36 PM   #7
In order to gain the most from a tri-y or 4-2-1 header, the camshaft needs to be correct for the header. By the way, so does the firing order. The tri-y or 4-2-1 header allows you to do things with the camshaft that most 4 into 1 headers will not allow, due to sizing and tuning requirements.
If you have, for what ever reason, an exhaust lobe that is too small, the tri-y will improve scavenging. Of course, if your valve or port is so small that you cannot get enough cam lobe on the exhaust, the tri-y will help there, too.
For a Chevrolet V-8, the "A" firing order, 1-8-4-3-6-5-7-2, and the "C" firing order 1-8-7-2-6-5-4-3 (AKA 4/7-3/2 swap) will work on the same tri-y header. The "B" firing order, 1-8-7-3-6-5-4-2 (AKA 4/7 swap) requires a dedicated tr-y header. Some merge collectors, as well as the Flowmaster "scavenger" collectors are also firing order specific.
Old 03-24-2012, 03:26 PM   #8
chassis1
Liked 9 Times in 3 Posts
Preach on alan!!!!!!!!
chassis1 is offline   Reply With Quote
Old 03-24-2012, 04:00 PM   #9
FINESPLINE
FINESPLINE's Avatar
Alan can preach on all he wants as I have read many to hundreds of his posts and the man is a wealth of information that I enjoy and appreciate. He is a straight shooter and right to the point . I would not think twice about PM ing for information I might need. Never met him and only recently seen a picture of him and I respect him. A good man on the forum .-------John
FINESPLINE is offline   Reply With Quote
Old 03-24-2012, 04:18 PM   #10
I also have a side line. I stand in as a scarecrow for farmers. It's boring, but it pays, and nothing will go into one of those fields if it has any sort of decent eyesight.
