Old 03-21-2012, 02:49 AM   #1
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default 327 MLS Head Gasket - Reuseable?
Getting ready to put the 275HP/327 back together. Can I reuse the FelPro MLS #1143 head gaskets? The engine only had 8 runs on it before I disassembled it, and the gaskets still look good (no tears in the coating). Any special prep when I reassemble?
Thanks for any and all suggestions!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-21-2012, 08:50 AM   #2
art leong
Default Re: 327 MLS Head Gasket - Reuseable?
Lew
Hi Lew. I reuse MLS head gaskets at least 2 times. First time I just put them on as is second time I use copper spray. I have even disassembled them and mixed and matched the inner shims. to adjust compression ratio
Art Leong 2095 SS
Old 03-21-2012, 10:42 AM   #3
Liked 1,913 Times in 429 Posts
I reuse my Cometic gaskets 2-3 times. Not sure how the Fel Pro holds up doing that.
Old 03-21-2012, 10:57 AM   #4
Lew Silverman
Thanks so much!
I guess I'll be OK with at least one re-use. The Cometic's are on my "wish list" for the next rebuild! I've got a can of the old K-W Copper Coat for a little bit of insurance.
Lew
Lew Silverman #2070
Old 03-21-2012, 08:59 PM   #5
Marine One
Marine One's Avatar
The beauty behind MLS is their ability to compress and seal. They are not intended for multiple reuses on standard production vehicles. With that said, we are not standard production / daily drivers running glycol / antifreeze.
If you plan to pull heads quite a bit, it makes sense to do what you can to salvage and reuse these as many times as you can. Since the problem would be head to block sealing, I would probably consider doing something to help identify potential H2O leaks entering the combustion chamber...maybe as simple as removing pressure from the coolant system before loading up and heading home, or take a baseline compression check with new MLS gaskets and use that as your benchmark to compare it to samples taken later in the season.
In addition, the smoother the surface finishes of the block / heads, the better MLS gaskets seal. Hope this helps.
Marine One is offline   Reply With Quote
Old 03-22-2012, 12:11 AM   #6
Liked 5,147 Times in 1,964 Posts
That's a .040 gasket. How far are the pistons above?
Old 03-22-2012, 02:32 AM   #7
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Lew, i know we had talked before about me coming back to AED in Richmond and it being alittle bit of a ride for you, but please check with me when you need parts. At one time (still going on) allot of the local engine builders were getting the cometics from us because our pricing was so good. Its worth a phone call to us alteast. (804-271-6076 ext 12), I'll do everything i can to help you guys out anyway i can. That goes for all our class racers, and the everyday customer. Did i mention we do ship UPS daily? May not be able to beat everyone's price out there but can come real close to them. Sorry to hi-jack the thread but just wanted to let you know about the pricing and when your ready for the cometics atleast let me price them for you. You might be surprised.....Thanks, Lil Duane
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 03-22-2012, 10:06 AM   #8
Lew Silverman
Mark,
I know I'm giving up a little bit of compression by going to the .040 MLS gasket, the theory being that they might seal better than the steel-shim OE-style .018 spec gasket. The deck height was set at the .002 called for in the engine guide.
Lew
Lew Silverman #2070
Old 03-22-2012, 03:08 PM   #9
randy wilson
Liked 22 Times in 22 Posts
I have used cometics 6 times with no leaks. Just threw them away on the 7th, couldn't take the chance. Just saying.
don,t have one
Old 03-22-2012, 05:03 PM   #10
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
the cometics arent cheep but if you are careful you can use them several times. I have used them 3 times so far on my engine with no problems. .025 thick on my engine.
Mike Pearson 2485 SS
