Old 02-09-2012, 10:10 PM   #1
magnumv8
Default Edelbrock smallblock Mopar heads
FYI.....The first run of new NHRA legal small block Mopar heads (60767 and 61767) from Edelbrock are going to come through with the wrong sized valve guides and therefore will need to have them replaced for them to be used in stock.....Edelbrock is putting 11/32 guides in both heads when the LA used 3/8 and the Magnum uses 8mm....this issue is being addressed and will be rectified in the next run (whenever that is, they were vague on production run schedules based on how soon they would need to make more).....
D L Rambo......
magnumv8 is offline   Reply With Quote
Old 02-09-2012, 11:16 PM   #2
Ken Etter
Liked 87 Times in 9 Posts
Default Re: Edelbrock smallblock Mopar heads
Word in the pits is you better hold off on buying them. They may soon be "unapproved"
Ken Etter 7375 STK/5 SS
Ken Etter is offline   Reply With Quote
Old 02-10-2012, 09:10 AM   #3
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
D L Rambo......
Same deal with the early big block Chevy Alum replacement heads. They were all 11/32 new out of the box instead of the original 3/8. I did several sets and just had to resize the guides. No big problem.
Old 02-10-2012, 12:15 PM   #4
ppmracing
Liked 2 Times in 2 Posts
Hey,,, its the same with the heads for the BB Mopar ,,,thats the way it is,,
ppmracing is offline   Reply With Quote
Old 02-10-2012, 06:15 PM   #5
George Mirza
Looks like the new heads aren't legal for the '68-'71 340's. They are for the '72 & '73 motors and all the 360's. Must have something to do with the above deck piston, are the new heads closed chamber?
George
George Mirza is offline   Reply With Quote
Old 02-11-2012, 04:50 PM   #6
nolongerracing
Liked 72 Times in 27 Posts
Can't use them on 68cc 360 engines either!
nolongerracing is offline   Reply With Quote
Old 02-11-2012, 08:11 PM   #7
Ken Etter
Bruce told me last night not to spend the money because of he gets his way they won't be legal.
Old 02-12-2012, 10:16 AM   #8
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Sounds soooo Democratic to me. One guy plays God!
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
