Old 01-30-2012, 03:03 PM   #11
Dirk Olson
Liked 172 Times in 46 Posts
Default Re: Pinion depth and shims...12 bolt question
Alan, is right you will never get a good pattern on a used set. You can shoot for the moon but be prepared to have a less than ideal pattern.
Dirk
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 01-30-2012, 03:34 PM   #12
Liked 1,827 Times in 414 Posts
Rusty, just set up a free account at photobucket, and post your pics here. I really can't see pics on my phone well enough to see a pattern.
Old 01-30-2012, 09:18 PM   #13
Bob Bender
Bob Bender's Avatar
Liked 459 Times in 90 Posts
Originally Posted by Dirk Olson View Post
I agree with Glen, Pattern in the key. I assume these are pro gears? .028 to .031 to start, look at the pattern on drive side. I like to be a slight heavy on the toe side to accomidate tooth deflection. Like about .008 on back lash on new set with good runout on spool. If runout is more than .003 you will need to open the backlash up so that you get no tooth binding. This works for me and I will get 200 to 250 passes out of a gear set then cycle them out. Hope this helps.
Dirk Olson
5036 B/S
x2
Bob Bender 144 O/SA
Old 01-31-2012, 09:16 AM   #14
Rusty Davenport
Liked 101 Times in 27 Posts
Originally Posted by Bob Bender View Post
x2
what do you guys mean by "run out" on the spool ????
Rusty Davenport is offline   Reply With Quote
Old 01-31-2012, 09:25 AM   #15
tj310
Run out on the spool , gear not seated flat against the spool . Backlash will vary as the teeth move closer . ---Trevor
Old 01-31-2012, 11:41 AM   #16
Rusty, what you'd need to do, is take the gear off of the spool, put the spool back in the housing under a little pre-load, and use your dial indicator to check for any "wobble" on the face of the spool where the ring gear mounts. You don't want to see more than about 0.002", and of course less is better. Sometimes at 0.004", it gets really difficult to set a gear up.
This is usually not a problem. If your backlash does not vary more than 0.002" when checked at 4 to 8 places, 90 or 45 degrees apart, then runout is not likely to be a problem. I find this to be a problem in maybe 1-2 out of 30-50 spools or carriers. If it is a problem, you can often rotate the gear on the spool either 90 or 45 degrees, and solve enough of it to be able to proceed.
Old 01-31-2012, 11:45 AM   #17
Dirk Olson
What need to do is check the spool in the case, caps torqued, no ring gear. Take a dial indicator and set it so that you are measuring the surface the ring gear mates to the surface the ring gear is bolted to, rotate the spool, any movement off .ooo is your runout.
Dirk
Dirk Olson 5036 STK
Old 01-31-2012, 12:04 PM   #18
Rusty Davenport
Geeeeeeeessssssss.....you guys are the greatest....thanks for helping an old man. IF I WAS DOING THIS BY THE HOUR THE CUSTOMER WOULD HAVE TO GET A HOME EQUITY LOAN !!!!!!! HAHAHAHAHAHAH Actually it has been really interesting and I am so thankful for you guys helping me along with some others, plus I am not in a hurry. When my patience starts giving out I just cut the lights out for a few days and come back later. Thanks again all of you. Keep the info coming. This website is really a good thing.
Old 01-31-2012, 12:38 PM   #19
Rusty,
Glad to help. If you need to send pictures you can send them to my email address and I'll be glad to take a look. By the way, I might be interested if the 5.00 gear is for sale.
Old 01-31-2012, 01:12 PM   #20
Glenn Briglio
Glenn Briglio's Avatar
Liked 971 Times in 308 Posts
Dirk
+1 Very important to check , if this is off forget about getting consistent backlash and pattern. Also check runout on ring gear after checking spool runout. That is with ring gear mounted on spool torque to the correct specs.
