Liked 101 Times in 27 Posts
Taking out a Richmond 5.00 gear and putting in a used US Gear 4.88......the US gear pinion depth has been done away with by a previous owner so I am playing with trial and error even more than usual.....if I hold the same pinion depth as the Richmond gear that came out I will have to add .090 worth of shims.....is that considered an unusual large amount of shims to any of you 12 bolt experts ??? (The pinion head of the Richmond gear is that much thicker......concerns me where to start...... I always read about starting at .035)
Liked 1,836 Times in 417 Posts
Yeah, 0.090" of shim is a ton. I'd start with 0.035", and about 0.010" of backlash, and go from there.
Alan Roehrich 212A G/S |
I did 2 sets last week .030 .038. gave up on pinion depth setters years ago. ---Trevor PS it's not a 3 series gear going on a 4 series carrier?
Liked 972 Times in 309 Posts
Liked 705 Times in 219 Posts
In my experiences of setting up rear ends,a 3 series gear set on either a 12 bolt or an 8 1/2" 10 bolt, an.030" pinion shim is usually about perfect. For a 4.11 to a 4.88,use either a.031-.032' shim, and with gears in the 5's or a 6.14, use a .033 shim The small pinions need to be set a little deeper in order to achieve a pattern centered on the ring gear. I probably have set up an honest 100 rear ends in my life.12 bolts are pretty consistant in what shim to use.
thanks for all the replies, I'm trying to read the paint on the ring gear but that is a little more challenging than I anticipated. All the preloads are perfect, just the mesh torments me......may just put it together and run it !!!!!!!!!!!!! ahahahaahahahah
Liked 204 Times in 54 Posts
Do you guys get the click-click-click-click-click-click from your 12-bolt rear end gears after a few transbrake launches? I have a 8.8 that still has the right gear pattern (and no cracks or visual anomolies), but makes a clicking noise when I spin the tire. The noise started after about ten, 7000 rpm launches......
Liked 172 Times in 46 Posts
I agree with Glen, Pattern in the key. I assume these are pro gears? .028 to .031 to start, look at the pattern on drive side. I like to be a slight heavy on the toe side to accomidate tooth deflection. Like about .008 on back lash on new set with good runout on spool. If runout is more than .003 you will need to open the backlash up so that you get no tooth binding. This works for me and I will get 200 to 250 passes out of a gear set then cycle them out. Hope this helps.
Dirk Olson 5036 B/S
Dirk Olson 5036 STK |
#9 | |
#10 | |
That is really interesting....would anyone let me text the pictures of the pattern to them for an opinion ??? Phone number ??? |
