#41 | |
Liked 68 Times in 41 Posts
have you tried a different carb?
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
#42 |
Liked 880 Times in 311 Posts
Ben,
I built a new engine for a customer and it missed and popped from the very first time we started it. Took it out of the car and put it on the dyno and all was fine. Changed everything in the car we could think of. The last thing we changed was the master cut off switch. We should have changed it first.
Adger Smith (Former SS) |
#43 | |
Now that you mention it, I've heard of that happening before.
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
#44 |
Thanks to all for your input so far.
I've already got a #10 ground strap to one head, and I'm down to bare metal at both contact points. I'll add a second ground strap to the other head, just to be safe. Please keep the experiences and thoughts coming. It gives me places to look, things to check, and God-willing, the possibility of narrowing down the problem. -Ben |
#45 |
Did anyone mention a firewall feed thru for the coil wire, ?
#46 |
Liked 405 Times in 158 Posts
Flat lobe on exh would cause popping out carb.
If it's a miss while reving in neutral I would of closed off the choke and check the result. Also look down the throat while reving and see if it's a smooth pattern of fuel or blobs of fuel from the emulsion tubes on both sides. If it makes no difference, rev it and move the dist around(advance/retard) and listen for a difference. I'd also close the gap on the plugs to about .030 just to test. Another dist wired directly to batt and another carb will prove if it's external. Your saying you've switched dist and carb so next is; Comp check and leak down Valves are adj right.....you didn't leave the break-in valvesprings on did you??? vacuum leak, p/brake hose cracked or carb gasket etc? And the "out there ones" Same oil pan as the dyno? thinking oil pump sucking the pan because of lack of clearance and the resulting vibration/cavitation acting on the dist causing spark scatter. How did you lift the engine to install it? undo an intake bolt or remove carb and use lift plate? Check those area's for warp/vac leak |
#47 |
67camaroracer,
-coil is mounted on the firewall. No feed-through. Already replaced the coil and wires. goinbroke2, - car starts right up and fuel flow is smooth out of the squirters. Fuel pressure gauge is rock steady. - oil pan is the same as dyno, and oil pressure is good. - lifted the engine in the car via a carb-plate - break-in springs were changed on the dyno - while I haven't hooked up a vacuum gauge yet, I've checked for leaks visually. The engine is running rich as opposed to lean, so I don't suspect a vacuum leak. The unburned fuel brings tears to my eyes when it's running, and the plugs are all over the map, but mostly dark. -Ben |
#48 |
Liked 1,924 Times in 432 Posts
Ben, can the miss be isolated to one or two cylinders, or is it just a miss that moves from cylinder to cylinder?
With a completely different ignition system and carburetor having been tried, if I read correctly, you're starting to move toward a mechanical problem, as much as that is something you do not want to hear. I'd do a compression test, check the lash, check the lobe lift, hook an undampened vacuum gauge to a manifold vacuum source, and check the valve springs. You might try a fresh set of slightly (1-2 steps) hotter plugs, with a gap in the 0.026" range. Have you hooked a volt meter to the various 12 volt positive inputs to the ignition system? You might look for a voltage drop when the miss is happening.
Alan Roehrich 212A G/S |
#49 |
Alan said: "hook an undampened vacuum gauge to a manifold vacuum source, and check the valve springs."
Exactly what I was thinking. Found a lot of miss-fires other shops didn't seem to be able to find on my big old Sun Engine Analyzer bu using it's big, un-dampened vacuum gauge. Invaluable tool if you learn how to use it. You can even isolate the offending cylinder with it. Just put a short piece of vacuum hose between each plug wire and the cap. Using a long screw driver with a jumper wire grounding it to a good ground, touch the short pieces of vacuum hose to ground the spark for each cylinder. If it's a cam or valve or spring problem the gauge will smooth out a lot when you ground the offending cylinder. It will deflect some for any miss-fire, but much more with a leaky valve.
Ed Wright 4156 SS/JA |
#50 |
Liked 520 Times in 132 Posts
Ben when I tried everything I could think on mine a few years ago I just gave up and had Mike Bush completely rewire my entire car. Hope you solve this. trust me it will be something small when you find it. Ed
