Liked 4 Times in 2 Posts
Need some Tech support? Need to put some wheelie bars on our Challenger. curious on what type works the best? Leafspring or tubular. looking for as much adjustment i can get. it seems that most chassis cars have tubular and standard SS cars have Leafspring. just want to buy the correct ones.
Liked 14 Times in 11 Posts
Jim,
Why not contact John Calvert and see about his single wheel wheely bar? Or at least see what he might suggest?
Phil Saran Parker, Colorado |
Liked 15 Times in 7 Posts
jim how is your gt duster project going give me a call bryan 605-999-9220
This is for your Stocker Challenger? If you are running a leaf spring suspension, then you do not want to run a solid wheelie bar. I tried real hard to make it work and was unsuccessful. Many launches to the wall or centerline. Then I used the AJE wheelie bars and loved them. But then they were deemed illegal for Stock.
I believe the old tried and true leaf spring wheelie bar as offered by Competition Engineering and others is the cheapest, easiest way out. I've looked at the Ken Kier single wheelie bar that is Stock legal and like the concept. But I'm not sure he has one for a pumpkin style rear end like you have. I doubt it but call him and ask. I looked at the Calvert wheelie bar today for the first time. I like it. If I were in Stock, I'd buy it. Reason is it takes the same concepts as the AJE wheelie bars (using a rocker for leverage) but in a way that is legal. The AJE required brackets welded to either the rear frame or a crossmember for uprights between the bars and the frame. Come to think of it...as I'm writing this I'm thinking that if the hardware was bolted on then it would be legal. Hmmmm,,,
Jeff Lee 7494 D/S '70 AMX |
Jeff,
I have the Calvert bar on my 1967 E/SA Camaro. I built a re-inforced pad below the trunk floor to contact the upper wheel, and just adjusted the bar up so the upper wheel touched the pad. After my record run, our Div. tech director informed me that no part of the device can contact the chassis when it is "at rest". He made me cut the support springs down at the track to lower the bar, and actually checked it before my backup run to make sure the upper wheel was not in contact. Just a heads up before you re-work your AJE bars. He didn't like the bar, thought it might be changed in the rules for 2012. I think it's great, and a safety item in my opinion, I'm too old for them wild wheelies...lol Grant Eldridge E/SA 6650 |
