Since NHRA is coming back to my area, I just want to make sure my car will pass tech
I Bracket Race the car, that's it. So I will be Bracket Racing in the No Electronics Class at VMP The car in current trim runs in the 9.70's at 138 mph I have Cage, Window Net, Full Face, Gloves, Neck Collar and Suit. I do not have a NHRA License and the Cage is not certed I'm guessing I will need those also? Thanks |
#2 | |
Liked 3,184 Times in 973 Posts
#3 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Looks like I'll need a Diaper, License and Cage cert, I have everything else
Not too bad Diaper Manufactures , can someone point me in a direction here? TIA |
Diaper- Call DRE.
I'll bet you need a chute. You should need everything that S/G needs Chip Johnson |
Liked 6 Times in 2 Posts
You don't need a chute unless you go over 150 MPH and may not even need a diaper. Depends (no joke intended) on the track. 9 second bracket cars here in the Pacific N/W aren't required to have a diaper. (yet)
Dale Posnick |
Or slow the car down to run 10's and save a bunch of $$$$
2009 V/SA Record Holder |
Liked 13 Times in 3 Posts
I think ever one should be required to have a diaper. I know a lot of people don't want to hassel with one, But having wrecked a car after getting in oil put out by the car in front of me makes me feel that way. Spend 20 to 25 thousand dollars fixing your car because you wrecked because of someone elses will change your mind in a hurry. Also, how many times have you been at a track and there has been a lot of down time while they are cleaning the track after someone has oiled it down. Thats one of the biggest reasons I don't bracket race much any more. Way too much down time from clean up.
Chuck |
Liked 56 Times in 27 Posts
Csjta,
You have a PM...
Dave Ribeiro 1033 STK |
