Liked 6 Times in 3 Posts
In stock doses the piston need to have an nhra appovered stamp on it or just the correct part number from the apporved list?
Liked 10 Times in 7 Posts
As far as i know all it needs is the MFG. # from the list.
Liked 129 Times in 59 Posts
The Lunati's I bought had both, stamped into the face of the piston, "NHRA" and the part number. I'm not sure if every company does this, but I would bet that as long as the part number is on the approved list you should be good to go!
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 1,953 Times in 439 Posts
My CP pistons did not have an NHRA approved stamp on them, just the NHRA accepted number. My JE pistons all have the NHRA logo on them. You can run all sorts of off the shelf pistons from various manufacturers, many of whom do not even make a special piston for Stock Eliminator. So you do not need any sort of special marking.
Alan Roehrich 212A G/S |
Liked 10 Times in 6 Posts
Alan, I think if you have an aftermarket piston, not stock piston, without approved nhra # stamped on it, they would have you pull a piston out of the motor. Tom
Tom Moock 5704 STK |
Tom, I was referring to a special marking, like the NHRA logo on my JE pistons.
For example, my CP pistons just had C4CP on them. That's the NHRA approved number. If you put a set of Speed Pro/Federal Mogul/TRW pistons in, so long as they had the correct part number, I don't think they'd need a special marking.
Thanks for the info guys.
