Old 10-24-2011, 03:11 PM   #11
BlueOval Ralph
Banned
Default Re: Lifter ? sbc Hydraulic/stocker
You have a PM
Originally Posted by Alan Roehrich View Post
Interesting, since the vast majority of racing oils now contain a fair amount of molydisulfide additives.
I have had various DLC coating applicators tell me not to use certain motor oils, but they've never said anything about moly disulfide in the oil, and have in fact suggested oils with a fair amount of moly disulfide in them.
That's certainly a subject that requires a lot more investigation. I look at DLC coating as being problematic, at best, it often appears to create almost as many problems as it seems to solve.
BlueOval Ralph is offline   Reply With Quote
Old 10-24-2011, 07:54 PM   #12
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Lifter ? sbc Hydraulic/stocker
Originally Posted by Jim Woods View Post
Danny, let me know what you find out, i'm looking also
Two words for ya !
*****Call Alex .,.,.,.,.,.,.,.,.,.,.,.,.,.,.,.,.,.
Old 10-24-2011, 11:28 PM   #13
Rick Unterseh
Rick Unterseh's Avatar
Liked 31 Times in 7 Posts
I'd like to know as well..... Alex, PM sent
Rick Unterseh is offline   Reply With Quote
Old 10-25-2011, 03:38 PM   #14
Reed Granrt
If you all dont mind, I would like to comment some of the subjects that has been addressed. If you understand, this is a deep subject for my shallow mind but I know it will open the door for criticism and that is the way we learn.
Some place in this thread hydrodynamic wedge was discussed in connection with cam and lifters. You cannot have hydrodynamic wedge with relationship of cam too lifters. I wished we could. Hydrodynamic wedge can only be achieved with hydrodynamic lift. Theoretically hydrodynamic wedge is achieved as a member (crankshaft) rotates and pulls an oil film with it and then oil pressure is applied. If the pressure is correct, the crankshaft will go into hydrodynamic lift and will actually go into flotation with equal amounts of oil all around. If the pressure is too low or too high, the proper amount of flotation is not achieved and the crankshaft is either high or low in the wedge and the crankshaft can drop down or be pushed up and be riding on nothing but the oil film, but NO hydrodynamic wedge. Cam and lifter cannot have nor achieve hydrodynamic wedge as there is no pressure applied to put either into hydrodynamic lift and achieve flotation. The lifter is only riding on the oil film that is present or dragged into. This is two surfaces that is separated by a thin oil film and it is called elastohydrodynamic lubrication. It is only protected by the strength of that oil film. This is one of the reasons that synthetics has come into its own in the last few years. They can design and make synthetics that can withstand and hold that film strength even with the severe pressure applied with those huge valve springs used today. If the film strength breaks down and we get actual rubbing, it is called mixed lubrication. This is where DLC coatings have come in as of late. This has become a huge science in its own especially out of Germany. I hear people saying you cannot use this camshaft and or lifter with DLC coating. This is really a misnomer in that there are several matrices out there that can have DLC coatings applied. We have salesman that says you can do this and do that when in reality you can but only if the proper DLC is used. You cannot in all likely hood use the same coating on a cast lifter that you use on a alloy steel lifter. You also have to take into account what the DLC coating is rubbing on. Whether it is steel or cast or ?? Yes there are DLC coatings that will work on steel camshaft and another type that will work on cast camshaft but, in all likely hood, they will not be the same. Most of the companies here in the states can only apply a small selected variety of coatings and most have been developed for Indy or Nascar type engines. Just lately, has companies began to move into drag racing but the problem arises because of the different varieties of materials being used.
Also I saw a discussion of moly based coatings for camshaft/lifters and or bearings. I stopped using moly based engine assembly lube close to a year ago. Lake Speed Jr. told me of moly clashes with certain oil. He addresses it on the Joe Gibbs website. It makes you aware of why we can have problems on start up and even more so if we use coated bearings. Dart has just recently addressed this issue thru Melling in this article
http://www.enginebuildermag.com/Arti...conflicts.aspx
Moly paste can really raise havoc with bearing coatings as well as certain other coatings but especially with moly additive oils, which is a large percentage of racing oils. Moly also will blind most oil filters not to mention that it will not stay in suspension very easily.
Ok I have said enough and you can poke fun at my thoughts. I can take it cause the woman of the house can twist me inside out
reed
Reed Granrt is offline   Reply With Quote
Old 10-25-2011, 04:29 PM   #15
ron mattson
Liked 69 Times in 32 Posts
You can run a tool steel lifter on a cast cam with proper breakin and lubricant selection, with that being said you can run a tool steel lifter with the proper coating on multiple cams of the
right material/treatment processes with no issues. I have ran tool steel lifters from a few suppliers for over 5 years without a single failure using a few procedures and the cams have
been sold and look like new, i have reused one set of lifters on 3 cams and switched back
and forth with no issues. If things are done right you can run any oil you want, hope that makes things as clear as possible.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 10-25-2011, 06:13 PM   #16
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
All PM's replied to.
Thank you.
Alex
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 10-26-2011, 05:41 AM   #17
Rick Leininger Jr.
DO NOT use DLC coated lifters on a cast core camshaft. EVER.
Why is that?
Rick Leininger Jr. is offline   Reply With Quote
Old 10-26-2011, 08:34 AM   #18
Liked 1,914 Times in 429 Posts
Originally Posted by Rick Leininger Jr. View Post
Why is that?
After working with several people who had the DLC fail on tool steel lifters, when used on cast iron core camshafts, I spent a few hours speaking with several DLC applicators, including three who coat tool steel lifters for various vendors. Every single one of them stated without reservation that their DLC coating was completely incompatible with cast iron camshafts. Their position is that the rough abrasive nature of cast iron will always cause the DLC coating to "spall".
One of the DLC applicators said that it was possible to run DLC on tool steel lifters against a cast iron core camshaft, IF you also coated the camshaft, and used certain brands of oil. They wanted $1500 to coat one camshaft and one set of lifters. They refused to offer any sort of warranty that it would actually work. One of their representatives did however claim that there would be a gain of 30HP in a flat tappet Stock Eliminator engine from coating both the camshaft and the lifters.
There are some people who are running DLC coated lifters on cast iron camshafts, you will always find some people who manage to do things that do not normally work. However, when the people who apply the coating to the lifters, and charge $400 or more to do so, tell you that using it against cast iron is a recipe for disaster, and failures are common, proceed at your own risk.
Old 10-26-2011, 08:52 AM   #19
Chad Rhodes
I've got a few piles of scrap parts that will verif this. Btw little flakes of DLC coating will wreak havoc on bearings.
Chad Rhodes 2113 I/SA
Old 10-26-2011, 09:36 AM   #20
ron mattson
You guys are exactly right no DLC wrong type of coating, but there are ones that
work, you dont need a coating for hardness/wear resistance when you have a 60-65
rockwell lifter and a hardened camshaft you need one for lubricity.
Put a lubricating coating on two hard parts and the life is unreal!!! The military has been
doing this for years on parts more critical than our camshafts without failure. and its
not moly that s**T doesnt work on anything worth .02$
