Old 09-27-2011, 03:50 PM   #1
Stocker
Thumbs down Pinion offset
Do the pinion center in line with the car center line on nova 1970?
any input !
Thank,
Stocker is offline   Reply With Quote
Old 09-27-2011, 07:22 PM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: Pinion offset
any input !
Thank,
no, both axles are the same length therefore the pinion is offset
Old 09-27-2011, 07:58 PM   #3
1" to the right.
Old 09-27-2011, 08:09 PM   #4
Steve Hayward
1" to the right.
I thought some were offset BB were and SB weren't....... or something like that..........
Steve Hayward is offline   Reply With Quote
Old 09-27-2011, 08:23 PM   #5
Kenney Kelley
Liked 72 Times in 36 Posts
The offset is .520 to the passenger side on 1970 & 1971 rear end. KenneyKelley
Kenney Kelley is offline   Reply With Quote
Old 09-28-2011, 03:55 PM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
BB engine is offset in the engine compartment.
Offset is .520". If you measure from the end of the housing to the center of the pinion, the difference is about 1".
Tom - The offset is handled with the differential carrier, thus the axles are the same from side to side.
Old 09-28-2011, 05:17 PM   #7
Tom keedle
Tom keedle's Avatar
yep, that's what i was getting at...
(not too successfully i guess)
anyway, no, the pinion is not centered...
Old 10-02-2011, 08:01 AM   #8
Stocker
Thank ! everybody,
Mine at time is at .750 to the passenger side . The transmission tail is on the centerline So the drive shaft do not line up with the pinion.This bring an other question!
Is it better the put the pinion , on the car centerline or let it as is?
Old 10-02-2011, 10:25 AM   #9
Tom keedle
Tom keedle's Avatar
i suppose ideally but a little offset will not hurt anything (unless the drive shaft rubs on something like the driveshaft tunnel)
