Old 09-11-2011, 12:54 AM   #11
Default Re: Stocker block SBC
Originally Posted by Greg Reimer 7376 View Post
I gotta question. Will the 31161111SHP blocks legal with a 327?While a 327 and a 350 share bore sizes and almost everything else,the 327's were all 2 bolt main.Also, do these come with bushed lifter bores? The crank I use is the large journal steel forging. I have a few of these, so that's not a problem. Just thought I'd ask.
Greg, according to what I've read, what I was told by NHRA, and what Dart told me (I buy direct), that SHP block IS legal for all of the small block Chevy V8 combinations. No, they do not come with bushed lifter bores, they are however CNC machined for location, so it is not necessary to bush them to correct the lifter location.
Old 09-11-2011, 07:16 AM   #12
carl hinkson
Liked 18 Times in 10 Posts
We CNC machine all our blocks and we also have the ability to probe the lifters bores for locations and we have not found any problmes with the ones we have checked!!
carl hinkson is offline   Reply With Quote
Old 09-11-2011, 10:14 AM   #13
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Stocker block SBC
My main concern was with the 4 bolt mains. Most tear downs don't go that deep anymore, but I was concerned about the legality of that detail.It sounds like a great place to start. 350 010/020 blocks without core shift are getting more and more scarce. Why bother when we can get one of these!! Next question-- who is the smokin' deal for one of these?
Old 09-11-2011, 01:58 PM   #14
Jeff Lee
Jeff Lee's Avatar
4-bolt mains are legal for all applications
Jeff Lee 7494 D/S '70 AMX
Old 09-11-2011, 06:56 PM   #15
Jody Lang
Liked 89 Times in 28 Posts
So I can run a Dart block, yet I'm stuck running a stamped rocker arm?
I really don't understand some of the rules for Stock
Jody Lang is offline   Reply With Quote
Old 09-11-2011, 07:49 PM   #16
junior barns
Liked 20 Times in 14 Posts
Question Re: Stocker block SBC
How much are one of these blocks??
junior barns is offline   Reply With Quote
Old 09-11-2011, 07:59 PM   #17
Greg Reimer 7376
Jegs shows the 4"bore, 2 pc rear main seal block, Jegs pt #301-31161111 for 1499.99 plus $ 119 truck freight. That would be a good way to get one and save $140.00 sales tax. I should get rid of all my old stuff and buy one of these.
Old 09-11-2011, 08:41 PM   #18
Reed Granrt
Carl
Long time since I spoke with you. If you remember we talked eons years ago about reworking small block oil pumps. I to have CNC capability with two machines. I purchase a few Dart blocks and Bowtie blocks as well as PBM. I have 1 SHP and 2 Little M and a Big M and a Bowtie here now. But I do not purchase enough to buy direct at a great cost, so I purchase from a good vendor that handily takes care of me( they sort thru a larger inventory than I could ever keep to help me). Have you had the opportunity to check the SHP after several runs (circle tracks) and saw any problems with their integrity as compared with the Little M.. Have you noticed the inability to keep seal after severe use and walking around of the mains.
reed
Reed Granrt is offline   Reply With Quote
Old 09-11-2011, 11:24 PM   #19
Jeff Lee
Jeff Lee's Avatar
Go to the head of the line!
Old 09-12-2011, 12:57 AM   #20
carl hinkson
Originally Posted by Reed Granrt View Post
Carl
reed
So far we have seen no issues as we have 2 guys one with a twin turbo build that is making appox. 850 horse and another procharger build that is appox. 825 horse and both are 3 years old and still running great.
On most of the blocks we machine we do add main studs and when using head studs we use a .950 stud bottom tap the head bolt holes and drop a ball bearing in the holes and screw the studs in as it keeps the cylinder much rounder on the bigger bore blocks, Rather bottoming a .750 stud out on the top of the deck.
Most leak downs are right at 2%
Using a good hone and the correct stones are key to having good ring seal and long life.
Hope this helps
