Old 09-08-2011, 03:04 PM   #21
treessavoy
Liked 4 Times in 4 Posts
Default Re: 225 stock eliminator help
Originally Posted by Chris Barnes View Post
Buy Phil's Slant Six and run it as an SS/GT car...maybe get a fancy intake manifold somewhere. You could probably still run the original 7 1/4" rear end!
Chris Barnes
Wagons of Steel
Stock 6621
Chris,
I raced a 225, 4sp Valiant in 1964.....bone stock, I broke 5ea 7 3/4's in one year.......8 3/4 is the only way to go.
PS. never lost a street race to another 6cyl the entire I owned it.
JimR
Jim Rountree
Old 09-08-2011, 06:39 PM   #22
Paul Wong
Liked 419 Times in 85 Posts
if you want to run under the modern index with a stick, the 8 3/4 will never last either. besides that all the ring gear selections you need are obsolete.
Paul Wong is offline   Reply With Quote
Old 09-08-2011, 09:16 PM   #23
Todd Boyer
Liked 6 Times in 5 Posts
Jeeeez, whaddaya gotta run - a Dana ???
Old 09-09-2011, 01:32 PM   #24
mtkawboy
Liked 54 Times in 18 Posts
If it hooks hard enough that you need a Dana 60 the cranks will start to break at the rear flywheel flange. The motor will still run, the car just wont move. I went thru that with an H/G Anglia with a slant 6 back in the early 70s, broke 3 of them.
mtkawboy is offline   Reply With Quote
Old 09-09-2011, 01:50 PM   #25
Paul Wong
The 8 3/4 wont live behind a 273 2 bbl, so i dont see how it will live behind a 225. I have these combinations in cars (both A and B body) running right now so I am telling you from life experience with current cars not hypotheticals. The 5.38 and up ring gears are obsolete from good manufacturers. If you stick with an automatic (no pun intended) you wont have any problems. If you want an index car you may be able to get away with cutting the corners.
Old 09-12-2011, 04:41 PM   #26
Chris Barnes
Is there some way to medicate Slantsixitis?
Chris Barnes
Wagons of Steel
Stock 6621
Chris Barnes is offline   Reply With Quote
Old 09-12-2011, 10:23 PM   #27
House of Darts
Liked 20 Times in 15 Posts
Yes Chris there is. $800.00 . 6 passes. 1. 15.65, 2. 15.42, 3. 15.32, 4. 15.75, 4. 15.30, 5. 15.15, 6. 14.98, 7. 1 broken crank. The webMD diagnosis... a V8.
House of Darts is offline   Reply With Quote
Old 09-12-2011, 11:33 PM   #28
Phillip marvetz
Phillip marvetz's Avatar
Well that proves it, They always run best right before they blow up.
2009 V/SA Record Holder
Old 09-13-2011, 02:17 PM   #29
mtkawboy
Just curious, where did the crank break, not the track the place on the crank ?
Old 09-15-2011, 12:45 AM   #30
treessavoy
They usually break at the flange or kick no. 6 rod out.....at least that's where mine always failed.
JimR
Jim Rountree
