Liked 279 Times in 68 Posts
How much are you paying for Purple by the drum? I had a guy quote me $415 or $7.65 a gallon which is $85 more than I paid in the spring [$330].
Greg Hill 4171 STK |
Liked 500 Times in 91 Posts
Last time I went to the pump, it was $7.05 a gallon. It's always fresh at this station also, it's right down the block from County Line Dragway.
Casey Miles 248H Stock? Last edited by Casey Miles; 09-09-2011 at 10:42 AM. Reason: spellin |
Liked 12 Times in 4 Posts
I bought 2 drums earlier this year at $360 per drum
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.” - Aristotle |
Liked 1,826 Times in 414 Posts
Greg, you'd have to call Kevin and ask him, he'd know what we pay, and be glad to tell you.
Alan Roehrich 212A G/S |
Liked 13 Times in 9 Posts
Conventional wisdom would say that more octane would be slower in an engine that doesn't need it, BUT I think there must be some other properties about it that's better than the 110 Purple. It runs exactly the same in my lil' 4-cyl car, but seems to be about .03 quicker with the old 360 Magnum crate motor I had.
We back-to-backed 112 Blue with C12 in Fisher's Mirada, and the E.T. didn't budge -- but it's cheaper, and more stable than the VP. As with any fuel swap, you may have to play around with jetting to get the absolute best out of it. But, given the research I've done, I choose to run Sunoco Blue 112 full time in everything I have. For those in the east, call Danny Presnell at Bearden Oil, 800-704-1233, to find a distributor near you.
#6 | |
While "extra octane" may in fact be "wasted", the HP effect people see, if they properly jet for changes in the specific gravity of their new fuel, is due to the burn rate, not due to octane. The various fuels have fairly widely varying burn rates. For example, some engines with only 12.2 to 1 compression ratio may see a HP gain by switching from C-12 to C-14+ or C-25, simply because the burn rate in the other fuels is what "makes their engine happy". You would not think that would happen, given the accepted theory that "extra octane is wasted", since C-14+ is rated for 14 to 1 compression, and C-25 is rated for 15 to 1, as well as high RPM (for Comp eliminator and Pro Stock). But it does.
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 09-09-2011 at 11:43 AM. |
Liked 8 Times in 6 Posts
I use to pay $7.00 a gallon at the station accross from Firebird. About two months ago it went up to $8.00. I just got some yesterday and it is still $8.00.
Mark, I always run the Purple110. Infineon said they sell Sunoco, so I did not bring any with me. Last year I got to the Divisional and found out they only have 112. I had to drain the fuel system and use the 112. I did not notice any change in performance or the A/F ratio with the 112. I run a low compression 360 in my Duster. Raul |
I had some old Purple and when I went to fuel check, it passed, but lost most of it's color. The tech official told me to put some fresh Sunoco purple so that he could identitfy it by the color that I was claiming. I'm thinking that it was at least 1 year old fuel, when I was at the PRI show, I spoke to a Sunoco Representative, he told me that it has a 2 year shelf live on the purple fuel.
Casey Miles 248H Stock? Last edited by Casey Miles; 09-09-2011 at 12:01 PM. Reason: clarification |
What Alan said. There are more variables in fuel than just octane. Octane doesn't make power. Octane *allows* you to do different things with the engine that make more power. By itself, octane amounts to nothing more than "unburnable stuff", which allows you to run more ignition timing and/or compression without getting into detonation. Theoretically, the less octane the better, but again, you have to look at ALL of a fuel's attributes to determine it's efficiency and power potential in a given combination.
Here's an old chart that has a lot of different fuel properties listed... http://www.smithtex.com/racing/fuelcomp.html
Liked 18 Times in 10 Posts
We pay 6.45 a gallon with racer discount in Boise for 110 Purple, thats with your own container.
Gordie
Gordie Kissner SS 6010 STK 6010 Last edited by Gordie Kissner; 09-09-2011 at 01:24 PM. |
