Recently, I have received a large amount of concern over automatic transmission case breakage and safety concerns. I am interested in finding out how much a problem this is in the stock class. Your comments are greatly appreciated.
Tracy Winters |
Liked 1,907 Times in 427 Posts
Not a problem for us. However, we already approached NHRA, they are unwilling to accept aftermarket cases in Stock Eliminator. Well, at least for the automatic transmission cars.
Alan Roehrich 212A G/S |
Liked 13 Times in 7 Posts
The only time I have encountered trans case breakage was due to chassis flex. With a properly installed roll cage and proper bracing there should not be any case breakage. Solid motor mounts, rubber trans mount and no chassis flex should eliminated breadage.
Richard Grant 4988 STK |
Liked 12 Times in 4 Posts
I recently had this problem with the TH350 in my stocker. We never could figure out why the case broke like it did, but I called Wesley (Div. 4 tech man) and was told that OEM case only. It seems as though NHRA would rather leave it alone or move Stock into Superstock rather than allowing more superceded parts like trans cases.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.” - Aristotle |
Liked 535 Times in 110 Posts
I've broken just one case in 30 years of racing and that was related to a U-joint failure....knock on wood!
Jim Kaekel 3836 STK |
Liked 70 Times in 29 Posts
I agree. I think using the wrong type of mount would cause our cars the most trouble. On a related note, do the JW bellhousings with the 30.1 flex plate sheild rating require indexing?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#7 | |
Banned
Liked 235 Times in 110 Posts
The bellhousing is SFI certified 30.1 for the flexplate shield and it fits onto the stock transmission case. You do not have to use an aftermarket transmission case. If I am correct the flexplate shield is required for vehicles running 10.90 or faster. I am not sure that I understand the question regarding the indexing? Let me know how I can assist you further.
Tracy- PM Sent
#10 | |
Liked 9 Times in 2 Posts
Larry |
