Old 05-21-2011, 03:54 PM   #11
junior barns
Liked 20 Times in 14 Posts
Default Re: Auto vs stick shift slicks
Originally Posted by Richard Grant View Post
Your question is what if you use bias tires on a automatic car, right? My experience is you will lose one tenth in et. Second, the air pressure will be lower. How much lower you would have to test. In the past you wanted to wrinkle the side wall in a bias tire and not wrinkle the side wall in a radial. I run 18 to 24#'s in my radials. Anything lower and they stop working. I would think the bias would be 18# and lower until it hooks right.
Not to hijack this thread but should a radial slick ever wrinkle much on the launch?
junior barns is offline   Reply With Quote
Old 05-21-2011, 09:21 PM   #12
Alan Warman
I run Toyo's on may J/SA Cutlass. They say the Toyo's are made for a stick car, but as cheap as they are I tried a set. I run 1.55 to 1.58 sixty foot times. They are also very consistent. I run 15psi on a 8" rim.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 05-21-2011, 11:12 PM   #13
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Originally Posted by Mike Taylor 3601 View Post
Only answer I have is probaly try and see,I want to try opposite we tried a little once using radials on stick car did'nt work at all when we tried but I will probaly try again when I have the chance,before I say it won't work.
Using stick tire I think could work your brother could be right auto may not hit them hard enough to plant the tire,but are'nt the radial sidewalls about as stiff as stiff sidewall stick tire?
I never say this can't be done or that can't be done,cause I've seen alot things that work now that was never thought possible,years ago.
What happened to you that your brother turned out right and you have automatic,where did your parents go wrong that you turned out that way? LOL
Mike Taylor3601
There are plenty of stick cars in Comp and SS running radials. You really need the proper clutch setup to pull it off. The complaint I've heard repeatedly is, there's no recovery time in the radials. In other words, if you spin, you'll keep spinning which leads to aborted runs. It's no secret...your clutch makes or breaks ya! Literally.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 05-22-2011, 08:15 PM   #14
Joe DeMarzo
Liked 121 Times in 11 Posts
Alan how cheap is cheap on the Toyo bias tire?
Richard worried about hooking not ET at this point, need some consistency.... Will never run with the bad ***** cars, lol.
Joe DeMarzo 1317 STK
Old 05-23-2011, 12:43 AM   #15
Alan Warman
Joe
My car will hook any were, mainly due to the the HP it don't have(LOL)
When you can catch them on sell they cost 220.00 a pair to your door.
Alan Warman
STK 4107
Old 05-23-2011, 08:06 AM   #16
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Joe, what compound have you run? In my division, Donnie Hough's car will hook anywhere even in the left lane at Shreveport. I would look at your suspension setup and the compound that you run. I found that the reason that Donnie was hooking and I wasn't was because he runs Hoosiers CO6 compound and I was running CO7's. My car was hooking anywhere except the local track often call Spin City.With a good shock(Sanhuffs if you can afford), Caltracs/CompEng bar, Caltrac springs, loose front end, etc. the radials will hook as good as any bias tire. Hope this helps.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 05-24-2011, 02:21 PM   #17
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Alan don't most run 26-28 LBS in radials 15 would explain that much wrinkle.
Mike V,
Auto guys also say that if radials spin they keep spinning
Mike Taylor 3601
Old 05-31-2011, 09:09 PM   #18
trmnatr
Anyone using M/T L8 compound? Have used it on a couple different sizes with good results, 32x14 and 28x9
Going with another set now
trmnatr is offline   Reply With Quote
