Hey guys, im trying to mount an alternator on a 69 camaro w/ a small block. I would love to mount this low as to clean up the top of the engine. Im using a cs series delphi alt. And the low mount brackets i have do not allow frame clearance on driver or pass side. Im sure ive seen this done but cant come up with what brackets will work. The ultra mini alts dont really give more clearance because of the depth around 5 inch... anyone have a clue ?? thanks !! Roger
Liked 136 Times in 49 Posts
I use the low mount on my Nova (same frame) I had to make a couple of spacers and move the bracket out about 3/4 inch. I also reclocked the alternator to help clear the charging stud.
Liked 99 Times in 60 Posts
Novassdude,
send me your email address in a PM, I have some photos that might help. Larry Woodfin
Larry Woodfin 471W |
Liked 536 Times in 110 Posts
Jim Kaekel 3836 STK |
OOOPS, I mean Roger send your email in a PM, my bad.
Roger try Alan Grove.
Mid mount #235R might work. ![]() Here it is with a CS130, you can modify the wp tubes for different type pumps. ![]() |
I used a nice billet street rod piece from Jegs to mount a stock alternator.
Ed Wright 4156 SS/JA |
Liked 3 Times in 2 Posts
Thank you guys for the help ! Ive got a bracket assembly coming that should fix me up. I appreciate the input !
Liked 881 Times in 452 Posts
Low mount alternator bracket
SKU: 102174 Part No: 1000 $57.95 Modern Performance Classics 1-800-457-NOVA Talk to Rudy |
