Old 05-06-2011, 10:04 PM   #1
George Mirza
Default AIr bag/lift system for pick up
Who makes a good air bag/lift set up for a '05 Dodge 2500? I like the looks of the Air Lift 5000.
Recommendations?
George
George Mirza is offline   Reply With Quote
Old 05-06-2011, 10:14 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 555 Times in 216 Posts
Default Re: AIr bag/lift system for pick up
I have used the Firestone Ride Rite air lifts in 2 GMC 2500 pickups and they work fine and never leaked. I have a Lance truck camper and put 50-60 lbs in the air bags when I use the camper....I usually put a little air in anytime I tow my trailer even though I really don't need to.....
Rich Biebel
S/C 1479
Stock 147R
Old 05-06-2011, 10:57 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: AIr bag/lift system for pick up
I have the Firestone kit in my '04 2500 Ram and the Air Lift in my Class C Motorhome. Both have performed flawlessly. Neither lose air after sitting a while. Jim
Old 05-07-2011, 02:23 PM   #4
Philip Saran
Liked 14 Times in 11 Posts
Like Rich, I have the Firestone Ride Rite air bags on my 2004 Ford F350
and also haul a cab over camper plus tow a open car trailer. I also have
Rancho 9000 XL adjustable shocks all the way around on the truck.
I normally keep 10 to 15 lbs of air when unloaded and then air up as needed
when hauling a heavy load.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 05-07-2011, 02:48 PM   #5
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Don't think either system has a bad rap...but what I found helpful for towing the race trailer or our 15K pound fifth wheel is to review opinions on some of the RV Forums, I use http://www.rv.net/forum/ and found the tech section helpful. Once you've pulled Cabbage Hill or come down Donner Pass at 29 degrees and raining you start relying on the big RV contingent that travels all over the country...they have EXPERIENCE!!!
BTW, you can't beat Summit's price on the Air Lift 5000 if you order from them a lot and have their "pro" account.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-07-2011, 08:32 PM   #6
George Mirza
Thank you!
How about tires and tire pressures.
George
Old 05-08-2011, 07:52 AM   #7
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I bought the Airlift 5000 system to replace the overload springs on my dually R20 Suburban because I needed more adjustability. Once the leafs are cranked up the ride is terrible when the trailer isn't hooked up. There are a few brackets that need to be cut from the frame for clearance so I'll be installing them later this month. They also recommend that some pressure (5 psi) be kept in the bags at all times, even when unloaded, to prevent them from chafing.
Good luck with your installation!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 05-08-2011, 09:24 PM   #8
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Every truck I have owned has gotten air bags.
I prefer Air Lift products myself.
I run 10 psi unloaded and 60 psi loaded.
Well worth the money !
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 05-09-2011, 09:21 AM   #9
ron mattson
Liked 69 Times in 32 Posts
I think i have what you need brand new never installed, mine was for a 06 ram 2500 but
i will check if thy are the same. I just checked with air lift they are the same from 2003-2010
so i sent you a p.m. thanks
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
