Liked 99 Times in 60 Posts
I am curious about this issue. Through the years I have built a number of very nice, fast, reliable drag race engines. I rarely have any problems, Just the routine happenings of drag racing.
Mostly small block Chevy's but a few big blocks. The deal is, some of them milk the valve covers but some of them do not. It does not seem to matter what performance level or what equipment, some do and some don't. These are engines built for customers and for my own cars and does not seem to cause any problems, oil looks good, engines run fine and perform as expected. Aluminum heads do it more than iron heads. Also, if you run the engine to 200 degrees or so before putting in in the trailer that seems to help. Have others of you witnessed this happening? Do you have any explanation of why some do and some don't?
Larry Woodfin 471W |
I put a PVC valve on mine to stop that in cool damp weather.
Ed Wright 4156 SS/JA |
Ed, I may experiment with a PCV valve. What valve? Got a part number?
Liked 881 Times in 452 Posts
ARP makes fluid Teflon sealer for head bolts, never had the problem again. Be liberal with use.
Don't remember what it was for. Fits a 3/8" hose and plugs into a gromet in a valve cover. I tack welded a baffle over it inside the valve cover to prevent sucking oil. May as well find one that flows plenty of air. It's a legal vacuum leak after all. Think mine is for an early 454". That was 4 years ago, and I'm old.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 05-06-2011 at 12:38 PM. |
I always sealed head bolt threads. Only showed up on fall mornings after short run times. Mine seldom sees 140 deg that time of the year. Hard to evaporate condensation without warming up.
Liked 165 Times in 59 Posts
condesation is the culprate and extrem heat,,,,we only run our race engines a short time (yes we get them up to 180-200 during warmup) but during the coarse of the race season we have so many temp and humdity changes thru out the season the condesation will build inside the valve cover and stay there,unless we have an endurance race (many rounds or consistant running of the engine )i have seen it in the oil pan windage tray that the oil doesnt cover ,synthetic oil is not helping to keep this from happening amost like brake fluid ,i have seen it from my fleet to my stocker gmonde
Liked 330 Times in 178 Posts
if you are using Pennzoil it may happen seems some oil brands are prone to this too --we chased this for almost 3 months thought it was everything from leaky gaskets (head/intake) to condensation etc-- switched to Valvoline problem went away immediately --part of what we found is the condensation gets all whipped up in the oil and the result is that milky look--- so we started the engine ran it for a few minutes pulled the v covers and cleaned em with brake clean left the covers off for 10-15 min to let the stem evaporate and then reinstalled the v covers and went on our way---this only happened if ya only ran the car every so often if ya ran it every weekend did not seem to be a problem--we did install one of those plastic check valves from the v cover to the headers --valve is the vacuum takes about a 3/8inch ID hose the kind that went on a early 60s to mid 70s GM power brake booster seemed to help a lot too--just my experience--Comp 387
Liked 280 Times in 139 Posts
I used to run a pcv valve on my stocker helped with the milk issue in the v/ covers, one day we pulled the carb, and found the baseplate covered with condensation, which led me to believe it would contaminate the intake charge, also the car would go a few hundreths quicker with just open breathers. So now when I run it for a short time, shut it off, take the breathers off to let some air in to disapate the condensation. gsa 612
#10 | |
The other thing to consider is: what is the product of combustion? The pcv may be the solution. I run one but didn't at first. |
