Liked 302 Times in 73 Posts
Are they available to buy outside of owning a CJ? thinking about a bracket car combo and want to keep it all Ford products no more powerglide.. not that it really matters..they're probably identical.. just thought it'd be cool to have one...
Liked 26 Times in 11 Posts
Reid Racing
2 pc. case with removeable bellhousing |
it IS a powerglide
Chad Rhodes 2113 I/SA |
have either of you actually seen one or are you just throwing useless info? any CJ guys out there no for sure?
Liked 5,145 Times in 1,964 Posts
Look familiar?
Sponsor
Liked 59 Times in 12 Posts
It is a PG with a Ford bell. I designed the first 3 proto type converters for them. Ford front mounting cover, from there back all GM.
Thanks guys I figure that's what they were but couldn't find a pic like the one Mark posted. since I already have one makes it a lot easier to consider this project.
Liked 320 Times in 102 Posts
Great information....
I went to my rulebook and in the Stock Eliminator, Drivetrain Section Transmissions, Automatic I found that "NHRA-accepted adapter plates permitted" and would possibly allow me to run a 904 Torqueflite behind my Pontiac engine. I went to the NHRA website to look in the Accepted Products section for an adapter for a Pontiac Engine to 904 Torqueflite transmission. There isn't a section in the Accepted Products identified as "NHRA-accepted adapter plates" Ther are no adapters listed so either all adapter plates are legal or no adapter plates are legal I guess that it might be located in the East Coast on-line version of the NHRA rulebook. Bob
Liked 16 Times in 11 Posts
Whatever rule book, just run a Pro trans and you will have your 904.
Bob Pagano A/SA |
But the difference is that one of them is built in a stock 904 case and costs X amount of dollars and the other is a 904 built inside of a TH350 and it costs XXX dollars.
Neither is cheap but one them costs about 3 times as much as the other...for the same performance!!! Bob PS: I have no axe to grind with the Smith's...good people who build fast cars and transmissions...even raced against them in the same class 30 years ago.....
