I have been looking at my solid lash adjusters. And there is no room to get a feeler gauge inbetween the valve and the rocker (the rocker has a channel that rides on the valve)
![]() ![]() I can measure the distance between the cam and the roller on the rocker. ![]() ![]() The only way I can adjust them is to do it one cylinder at a time (2 intakes or 2 exhausts) Then pull the cam and adjusters lock the locknuts, then recheck them. Then move on to another pair of valves Any ideas on an easier way to do it?
Art Leong 2095 SS |
Liked 973 Times in 310 Posts
Artie split the feeler to desired width.
Liked 333 Times in 180 Posts
Art---see if ya got any motorcycle mechs around they have the same situation with the Jap bikes take a rocker over and see if one of their feelers will fit in your rocker--also ya using the PT cruiser NA rockers ??? they will take a lot more/higher rpm than a stock one---look at a set of DRAPER feeler gauges usually kinda long narrow tips lotsa bike mechs use this type
#4 | |
Using 2.7 rockers they are a bit better than the PTs
Art Leong 2095 SS |
Art---what you are looking for is TAPERED feeler gauges---they have a narrow point you stick in the rocker then get wider as they go back towards where ya hold em
I just bought a set of Honda motorcycle gauges on Ebay I might have to trim them but they look like what I might be able to use.
Art Leong 2095 SS |
probably metric tho---ya need standard
HONDA! Eeeeeeeeeeeeeewwwww! Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Banned
See if you can find one of the old P & G Valve Gapper A toll that was around in the 60"s and adpt it I have 2 but wouldn't part with them for the world.
Ralph beat me to it. I also have one, but it was a gift from my wife. Would not part with mine either. Can you somehow use a dial indicator? That was my first thought, then scrolled down (iPhone) and saw Ralph's post. A bright guy like yourself can come up with a way to use a dial indicator. Think you'll like it.
Ed Wright 4156 SS/JA |
