Liked 963 Times in 193 Posts
Does anyone make racing front coil springs for a big,or small block Impala?
Liked 129 Times in 59 Posts
Lyn,
I know that Santuff makes a front spring; they'll need to know the front end weight in order to give you the proper height and load capacity. You also might want to check the Moog catalog for a reference for an OEM replacement spring. Good luck! Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 230 Times in 106 Posts
Lyn,
Ran a 69 impala for years. If I remember correct, we used a BB Chevelle spring and then had to cut a coil or so off of them. |
Liked 410 Times in 94 Posts
Moroso has them
