Old 03-18-2011, 12:50 PM   #1
Jim Storms
Liked 4 Times in 2 Posts
Default 70 Duster, Brake & Spindle???
we are finishing our 70 Duster! the car was originaly a Kelsey Hayes disc. brake car, we bought Strange front brakes, but there not right for our spindle, and they say they dont have one for that spindle, has anyone used this spindle with aftermarket brakes? Strange,Wildwood, Aerospace. or do i need to change the spindle.
Jim Storms is offline   Reply With Quote
Old 03-18-2011, 01:32 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 858 Times in 234 Posts
Default Re: 70 Duster, Brake & Spindle???
From my experiance ,you must use the drum brake spindle with Strange and Wilwood.
I dont know if anyone else makes one for the disc spindle.
Old 03-18-2011, 01:38 PM   #3
Paul Wong
Liked 419 Times in 85 Posts
Jim,
Depending on the brakes you bought you will either need to use a 10" b body spindle or a 9" a body spindle. The only one that will make the brakes for your configuration will be lamb.
Paul Wong is offline   Reply With Quote
Old 03-18-2011, 01:40 PM   #4
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Jim, what Paul wrote ... on my Barracuda I used 9" drum brake spindles from an A body. Should not be too hard to find .. NAPA still has upper and lower ball joints for them ..
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 03-18-2011, 01:48 PM   #5
Paul Wong
thanks I forgot to mention they have to be drum brake spindles
Old 03-18-2011, 02:16 PM   #6
STK4340
FWIW, I have the Strange set-up on my car and use the original '73 disc brake spindle. I do know for sure that they are different from the earlier disc brake spindles.
STK4340 is offline   Reply With Quote
Old 03-18-2011, 02:41 PM   #7
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Wilwood has a kit for the 10" drum spindles.That's what I put on the front of my '71 Demon.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 03-18-2011, 03:00 PM   #8
Jim Storms
Thanks for the info.. i found out yes! i do need to put a 9" drum spindle on the car. seams to be the standard one to use...did not know these Kelsey Hayes set up was so different.
Old 03-18-2011, 11:27 PM   #9
Philip Saran
Liked 14 Times in 11 Posts
Jim,
If you decide to look for parts, take a look at these web sites.
www.fourabodiesonly.com
www.moparts.com
www.barracudaowernsgroup.com
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 03-19-2011, 12:38 AM   #10
70AARCuda
Liked 11 Times in 6 Posts
www.forabodiesonly.com
70AARCuda is offline   Reply With Quote
