Liked 244 Times in 26 Posts
I've been reading some engine books recently and it got me thinking about spark timing and different engine combinations in S/SS. In general, the better the combustion chamber and intake quality, the less spark timing is nessary. Would folks be willing to share what timing settings work best for you with your engine combo and fuel?
I'll start. Our 4.3 chevy v6 liked 40* with c10 or c11 fuel in stock eliminator. |
Liked 7,925 Times in 1,760 Posts
Chris, excellent subject but, I think that it is a subject that becomes too "singular" in scope. If we can agree that, after a certain point, timing becomes a "crutch" then you will know what I am meaning by it being too "singular".
Most of the "stuff" that I'm playing with right now seems to naturally want about 33 or 34 degrees total. That being said, this past year, I took one of my motors and installed it in a car weighing almost 400 lbs. more than what it is usually in and the same motor/trans/converter (more gear) wanted 6 degrees more timing to "peak" its ET. I think that you're truck is a good example of that because (IMHO) I don't believe that you're motor (using C-11 especially) should need 40 degrees of timing. Please reply as this is a subject that really does interest me.
That's a lot of timing, particularly for an iron head engine.
Ed Wright 4156 SS/JA |
#4 | |
Art Leong 2095 SS |
Art, generally, the higher the octane the fuel, the slower the burn rate, the reason to need more timing.
Liked 69 Times in 32 Posts
Octane definately matters, as does geography, the timing you would use at the coast
in sea level or better air is going to be different than what you would use in the minnesota swamp bp of 28.50 or denvers 5,000 plus ft elevation
Ron Mattson 5015 STK Last edited by ron mattson; 03-08-2011 at 10:25 AM. |
#7 | |
We had a lot more cranking pressure that the SS motors due to the big cams they ran. It wanted the timing and the fuel. I believe I told you how we corrected our timing when we were at a race? Water pressure!!!!! Worked like a charm.
Art Leong 2095 SS Last edited by art leong; 03-07-2011 at 09:27 PM. |
When we ran Denver we just bumped the timing 4 degrees. And were able to run the index. Never touched the carbs
Art Leong 2095 SS |
Art, what did the turbo cars like for timing?
I used stock ecu's so timing was controlled by the computer. I would set the intial (distributor) to 18 or 20 degrees
Art Leong 2095 SS |
