What is the advantages and/or disadvantages of shutting your engine down after you go through the lights on the high end? I know for a plug check is one but is there any other reason beyond that?
Nelson Kowal Stock 345 |
One advantage (depending on your oiling system) is not uncovering and loosing oil pressure during deceleration.
Bill Edgeworth 6471 STK |
Liked 6 Times in 2 Posts
One thing to remember is when the engine is shut off after you clear the lights, your not supplying an fluid to the trans, at 130mph or more, that could be disaster, unless you leave the motor idle with the trans in neutral, if you have a trans and shifter with a clean neutral ! Much safer !.........John
John Lang 365 STK, SS |
#4 | |
Liked 772 Times in 192 Posts
Liked 464 Times in 113 Posts
yup!!!!!!!!!!!!!!!!!!!!
68 Chevy11 327 F/S |
![]() Agreed. X2
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
Liked 8 Times in 7 Posts
Liked 410 Times in 94 Posts
That's another reason why everybody needs a clutch
Jupp B/S 348 |
Banned
