Old 02-05-2011, 01:29 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default What to add in radiator?
Since we are not supposed to run anti-freeze in the cooling systems
at the drag strip, can a anti-rust additive be added to the radiator?
What about water-wetter?
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 02-05-2011, 02:25 PM   #2
nickh
nickh's Avatar
Liked 650 Times in 194 Posts
Talking Re: What to add in radiator?
Royal Purple "Purple Ice" is great stuff, so is Redline Water Wetter.
nickh is online now   Reply With Quote
Old 02-05-2011, 04:52 PM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: What to add in radiator?
X2 on the Water Wetter
Old 02-06-2011, 09:51 AM   #4
james schaechter
Liked 1,436 Times in 299 Posts
If you leave the water in the radiator for general racing or between races, it is good to dump some anti rust and water pump lube in. It is cheaper than the purple ice and redline stuff. It isn't something to help cooling like those are, but it does help protect your radiator and water pump.
Some areas have really bad iron and hard water deposits in the water so keep that in mind, especially if you don't drain it after the races each day.
James Schaechter 3163 STK
