Old 11-18-2010, 02:32 PM   #1
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Default IHRA Crate Engine cam spec question....
When building a crate engine, do I need to use the exact camshaft part number listed on the tech sheet in the engine build, or can I have a custom grind made with the same lift specs as stated on the tech sheet ? (with any duration)
Thanks
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 11-18-2010, 02:41 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: IHRA Crate Engine cam spec question....
Get a custom grind. I've used both B & C brands from the Memphis area. Actual lift at the valve is all that is checked. Another tip: What ever brand rockers you use make sure they are not stamped with the ratio.
Adger Smith (Former SS)
