#51 |
Well obviously if both cars leave at the same time, then the FIRST red light would be the WORST red light. I was referring to anywhere with a handicapped tree, most would realize that. The slower car has the advantage of the clean tree, the fast car has the advantage of the First red light. I don't see the problem with that, neither does most of the class racing, and bracket racing communities.
Chad Rhodes 2113 I/SA |
#52 |
Liked 316 Times in 67 Posts
I guess I'm in the 5% advocating worst red light loses. Many want the "driver" to be recognized in the equation, a .495 red vs a .437 red would indicate that the first red light did a better job of driving
True, there are equal advantages (now) with clean tree vs first red light, but conveniently ignoring the better advantage of having the race in front of you...the best advantage Not a big deal to me compared to mufflers, better hooking consistent tracks, better pits, shorter races, consistent tech and on and on....just voicing my 5% |
#53 | |
#54 | |
Banned
Liked 235 Times in 110 Posts
#55 |
Liked 1,954 Times in 440 Posts
And the slow cars conveniently forget the advantages they have, not seeing the other car leave first, less time on the chip, the converter, and the brakes, as well as less worry about the rapidly growing problem of questionable track prep.
If you built a slower car knowing about the first red light rule, well, you knew the rules, they haven't changed in around 45 years. I guess you'd build a house between an airport and a landfill, then complain about jet noise and the garbage smell.
Alan Roehrich 212A G/S |
#56 |
Liked 573 Times in 67 Posts
#57 |
Liked 43 Times in 10 Posts
#58 |
the clean tree would be that the slower car doesn't have to block out the distraction of the other car's lights coming down (some trees have dividers, some do not). You also don't see the other car leave out of your peripheral vision.
#59 |
I have only met a few racers that honestly prefer being the slower car all the rest are just racers that say that because they can't afford to be the fastest car. We've had the Xmas tree since the early 60's but until the reaction timer was introduced the slower car didn't know he had done a better job of driving only to be eliminated. Just as the best light's reward comes as a finish line cushion. The worst red light should be grounds for elimination. I'd like to hear some more about all those advantages that the slower cars have other than costs. LOL Maybe the rules haven't changed in the past 45 years but a whole bunch of variables sure have been introduced in that time that these old rules do not take into account.
#60 |
exactly. When big money bracket races, NHRA's bracket series, and local tracks go to a WORSE redlight rule, then it might be time to think about it for stock/SS/Comp. But Stock and Superstock is not the place to try this experiment.
A question for the proponents of this rule, name me one track in the US that uses a WORSE redlight rule in their weekly bracket program?
