Chrome moly NHRA certified until 5/12
Built by Suncoast with updates later. Bars up front for front fuel cell. Fiberglass and removable nose, hood, doors, deck lid, dash and rear bumper. Weighs 2400 with BBC/glide Setup for BBC and Glide or TH400, have driveshaft for both (1350 solid u-joints) Coated 2 ¼” headers Strange aluminum struts with four piston brakes, and slotted rotors. Strange 1 1/8” bore master cylinder with coated brake lines. Griffen aluminum double pass radiator with fan TCI trans cooler with fan Dana 60 rear end with the following: • Double adjustable ladders bars. • Strange 35 spline pro race axles with 5/8 drive studs. • Strange spool with 4.88 richmond pro gear, and aluminum girdle cover. • Koni double adjustable shocks, with ride height adjustment. • JFZ calipers, steel rotors with aluminum hats. • Anti-roll Setup for dual batteries, 4 gallon RJS upright fuel cell in rear. BG 280 fuel pump with adjustable bypass. MSD 7AL-2 ignition ARC overhead switch panel Simpson parachute Spring loaded wheelie bars with x-brace Monocoque lightweight racing wheels Auto meter ultra-lite series gauges- oil press, water temp, volt, trans temp, trans press. Proven winner, Division champ car 2009. Available as complete roller-$14K or Turnkey with 427/481/540 and glide/TH400. Call ALEX 419-543-3315 cell. Mansfield, OH
Alex Miller |
you have a pm. thanks
