We have an Ed Quay 1986 Camaro SS/GT car and the headers on it now (small block) are not racer friendly and look to be very old. Looking for suggestions on a decent header for this car .It has the 69 ,350 motor in it. Help me out here if you can .Maybe someone has gone to a big block and have some small block headers laying around collecting dust .Let me know. Thanks in advance.....
Danny Waters, Sr / 73 Duster "340" |
Liked 53 Times in 13 Posts
Danny, hooker 3 step headers are nice if you can find them, they will fit unless your engine has been set back then you have to modify them to fit. I have them on my 95 firebird and had to make them fit due to engine set back... Luke SS 311
The ones on here now are very tight (touching trans pan on driver side) and have to take loose to change oil filter. The engine is more than likely set back . I guess Ed Quay does this when he builds them. Thanks again..... Oh ,this car was originally built for a big block when Ronnie Williams had it .
#4 | |
Chad Rhodes 2113 I/SA |
Thanks Chad . I'll get Jr to call Monday.
Liked 205 Times in 93 Posts
hi danny, i have a set i believe are hooker, off a SS/GT camaro/auto...1/3/4" tubes, 3" collector w/vac fittings. need adpt. plates, very solid cond. need a light scuff & paint...$350.00 if 'yer interested.
Danny, I have a 1983 Camaro that I built using Ed Quay parts to be super stock legal, including the modified front crossmember, I also used the headers he sells for his cars. When I purchased them it was suggested to get them just tack welded, which I did and was glad because most of the tubes had to be cut and repositioned before final welding. I also cut the flanges and made each side into three pieces which I found them easier to install that way. Bob at Quays is very helpful and patient. Good luck.
Liked 41 Times in 9 Posts
Call Pete Z....I ran his headers forever on my 87 camaro...he builds good pipe for these cars and is reasonably priced...also a nice guy too.
315-483-6412....... located in NY
Joe Franco SS176 |
