Old 08-15-2010, 12:55 PM   #11
Lyn Smith
Liked 997 Times in 201 Posts
Default Re: What company to buy the front disc barke kit from
I bought Strange .Had trouble mounting them because my original disc brake spindles had been replaced with some early chevelle drum spindles,and the upper bolt was smaller.One side seems to have more drag than the other.Have reshimmed the caliper a few times but has not changed it.Stops ,and holds in the water alot better though.
Old 08-15-2010, 05:11 PM   #12
Kegracing
I put Wilwood on all 4 corners of my 67 Firebird. Very happy with the kit components and function.
After I bleed them properly, they work great!
Ken
Kegracing is offline   Reply With Quote
Old 08-16-2010, 07:46 AM   #13
vonzipper396
I used wilwood HD vented rotor kit on my 3600Lb bb 69 camaro to replace the stock disc setup in front. Kept the stock MC & booster but it still knocked 40lbs total off the front and stops exactly the same as before(which is really good). A friend used the aerospace kit for a similar car and was very disapointed(would not slow a heavy car safely).
vonzipper396 is offline   Reply With Quote
Old 08-16-2010, 10:12 AM   #14
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
I put Wilwood on front and rear of my 62 Chevy. Drums being a bit lighter than OEM disk brakes... my weight savings were not as dramatic. I believe combined weight loss was 48 pounds.
The front was a staright forward bolt-on... though they DO move the wheel mounting outward about 1 1/4". If I did it again, I would do some more research to see if the other manufacturers have something that would put the wheels closer to factory location.
On the rear, Wilwood had no kit for a 59-64 Chevrolet, so I purchased the Ford 8" kit ( after doing some investigation, and calculating ). I then designed and drafted up my own mounting brakets, which were made by my machinist. Fit is flawless.
After a few "break in" stops... these brakes are effortless... and at 3650 pounds from over 120 MPH... that means something !
ID:	4392   Click image for larger version
ID:	4393   Click image for larger version
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 09-12-2010, 05:20 PM   #15
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Todd, what did you end up doing with the brakes on your GTO.
I have heavy stock front spindles and disc brakes on my Chevelle now. I have one bad spindle so I currently am contemplating installing my drum spindles and getting an aftermarket fron kit for my Chevelle 1970.
chris ok is offline   Reply With Quote
Old 09-12-2010, 10:44 PM   #16
Todd Hoven
Guest
Posts: n/a
I decided to go with Mark Williams in the front. I hope to buy them sometime next month, when I start working on my car. They seem like the best deal for me because they pay contegnecy....
Old 09-13-2010, 12:31 PM   #17
Dave1695
Liked 15 Times in 11 Posts
Call Stainless Steel Brake Corp. (800-448-7722), they have four piston comp calipers for most cars and are a contingency sponsor for IHRA. I have their stuff on my 3200 # Stocker and they work great in the box, on the line and and at the finish. They also have a cast aluminum Corvette master cylinder that is about 7 pounds lighter than the cast iron version!
Dave1695 is offline   Reply With Quote
Old 09-15-2010, 12:26 PM   #18
Dave1695
My last post was deleted, guess I gave too much info. best place for racing brakes Stainless Steel Brake Corp.
Old 09-15-2010, 08:25 PM   #19
340Cuda
Liked 805 Times in 341 Posts
Originally Posted by ss3011 View Post
Strange Engineering brakes are top notch. Straight forward to install and work great.
My experience as well.
Bill
