Liked 165 Times in 59 Posts
just built and installed 904 trans,,,,,heres the deal ,trans works great fast engagement from forward to reverse but have a serious leak from the bell housing (and of coarse you cant see any thing) change out the front pump seal from the new one that was installed new,checked pump alignment good ,when you load the converter it gets worse,,checked converter (brand new coan 5000 stall)welds look to be good but could be coming from there,,any one have to send a converter back because you cant locate a leak?any chance of the 904 early lock up case could be the issue not having a port exposed putting hight presure in the converter ??? i used the non lock up pump (two check ball pump) any input is helpful,,sending the converter back to have them presure test it
turbo action valvebody reverse manual coan converter aluminum front drum turbo action rebuild kit gmonde |
Liked 26 Times in 13 Posts
I had a converter do the exact same thing and it was a tiny pinhole in the weld. You could never see it with the naked eye. When you put some serious pressure in there, it's amazing how much fluid can come out of such a tiny hole. You should send it back to Coan and they should eat the cost!
Bill Harris ex 2172 STK ex 2272 S/S |
Agree...sounds like converter or front pump problem. Check pump bushing for wear? dial indicate Hub for run out and pump shaft for being bent. Might be a local converter shop locally that could check it quickly and cheaply for you....usually not an expensive deal. Check crank end for right size pilot hole early mopars about 1.51 and late around 1.66 ( could tell you exactly after home from Indy ) could be wrong size making it misaligned or cocked slightly. Do not know AMC size. Good Luck
Sponsor
Liked 59 Times in 12 Posts
Hi, check for a crack at the base of the slots on the drive side ( where the slot drives the pump lugs) It is a common problem with 904's and hard to see. Use a little fine polish on the hub in that area and the crack will show up.
Liked 121 Times in 11 Posts
This is why I love Lenny/Ultimate converters.....check the slots. Did you move to NC or AC? Garrett hope you find your issue and the trans is fast for you.
Joe DeMarzo 1317 STK |
update::: found the issue,,after pulling the trans for the third time ,i removed the front pump and looked closley at the small lubrication hole that are in the aluminum front drum,they line up with the vent holes on the back side of the pump,,this was filling up the vent and pushing out the front of the pump vent hole ,,so i tapped the hole and pluged it and redrilled the vent in the back of the case ,,loaded the converter hard and no leaks ,,got it down to 20 min to remove and 35 min to install ,,now we test and thanks for the input gmonde
