Old 08-25-2010, 01:54 PM   #21
JSLRacing
Default Re: 1997 Neon 4 door Stocker
This might an obvious statement but...
Can I remove the air bags.. and when i remove the pass air bag.. what can i put in it's place to fill the hole.. ( I'm not sure how the passenger bag is held in)...
JSLRacing is offline   Reply With Quote
Old 08-25-2010, 06:43 PM   #22
JSLRacing
I was looking through the IHRA Rulebook and 18.49 would put me in DF/SA..
I don't have an NHRA rulebook but I'm CF/S in NHRA?
Jason Goldsack -
1997 Track Champion - St. Thomas Dragway
1997 Race of Champions Winner - Indianapolis, IN Div. 3 finals
Old 08-25-2010, 08:23 PM   #23
DonatoEng
Liked 8 Times in 5 Posts
Have the dealer order you a Mexican Neon passenger air bag cover. The mexican versions had an insert for the dash to replace the US air bag.
DonatoEng is offline   Reply With Quote
Old 08-25-2010, 08:28 PM   #24
DonatoEng
If you run a manual trans you will need the gear set from a 1.6 L car. They had a 4.12 FD.
Old 08-25-2010, 08:30 PM   #25
JSLRacing
I will be running an Auto tranny
Jason Goldsack -
Old 08-25-2010, 08:55 PM   #26
DonatoEng
I have a manual in my CF/S Daytona, no problems.
Old 08-26-2010, 09:15 AM   #27
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Up until 2003, NHRA and IHRA had the same 16 FWD classes (AF to HF, stick and auto). IHRA still uses this format. In 2004, NHRA decided to go to four FWD classes. AF to DF, with sticks and auto's run together (sticks carry a 100 pound weight penalty). A few years ago, they added a new A class, and what was A through D is now B through E. It totally obsoleted my old car that I drove for Billy Nees. What was an HF/SA, 18.60 Index, 2,510 pound minimum weight in the 27.5 pound class, became a DF/S (now EF/S), 17.75 Index (that is now 17.45), 2,295 pound min wt, in a 25 pound class.
But yes, 18.49 makes your car a DF/SA in IHRA on a 15.60 Index, and it's an NHRA CF/S on a 15.15 Index.
Old 08-26-2010, 04:19 PM   #28
JSLRacing
I'm gonna need some good ponies to get my neon under the index then...
Jason Goldsack -
Old 08-26-2010, 06:14 PM   #29
Mike Carr
Mike Carr's Avatar
You can add/subtract weight, too, to move to a Class with maybe a better Index for that weight.
Old 08-26-2010, 06:20 PM   #30
Mike Carr
Mike Carr's Avatar
NHRA CF/S, the top of the class weight break is 17.5. Minimum weight for C would be 2,480 pounds. 15.15 Class Index
IHRA DF/SA, the top of the class weight break is 18. Min Wt for DF/SA is 2,546 pounds. 15.60 Class Index.
If your car can not get that light, you could always run DF/S in NHRA and EF/SA in IHRA (19 pound class for both, 2,678 pound min wt in both. 15.60 Index for NHRA DF/S; 15.90 Index for IHRA EF/SA).
