Liked 140 Times in 51 Posts
Does anybody make a stock appearing pan with a screen or tray built in?I have seen them for SBC,from Milodon etc.If not what do you guys recommend as far as baffleing etc,this is not a stocker but a street car that see's the track a couple times a year.I want to keep it stock appearing.Thanks in advance
Kevin |
#2 | |
Liked 1,579 Times in 582 Posts
You should also call Kevco Racing Oil Pans. |
MILODON for sure.
Danny Waters, Sr / 73 Duster "340" |
The canton and Milodon are stock pans with the same baffle as a GM production pan.With the stock GM pan you also use a bolt on windage tray with stand offs corrrect?The pans I am looking for have a windage screen or baffle mounted in the pan.What do most stock eliminator guys use for this application.Is the stock windage tray any good or even needed ?Thanks again
Kevin Last edited by SSGN; 08-17-2010 at 07:22 PM. Reason: More info |
Liked 1,814 Times in 413 Posts
We use a stock GM LS-7 pan, and a baffle between the oil pan and the main cap. Some guys use the approved Moroso pan that has a welded sump extension.
Alan Roehrich 212A G/S |
I saw that pan also.I want to keep the stock appearing though.I guess the biggist concern we have is ,is it worth any HP to run a windage tray mounted to the caps or just a good stock pan?Thanks for all the input
Kevin |
Call Kevco racing pans. They may make the pan or even modify a stock pan for you. They build a great stock appearing small block pan with built-in windage and trap doors. They are good people and very helpful.
stock appearing in aluminum?? Call Williams Performance Products. ask for Mickey. (951) 245-7144. best in the business
Big wheelies are for show!! Go fast or go home!!! |
