Old 06-22-2010, 04:39 PM   #1
7423
Default OEM FWD auto trans question for the tranny guys
Would like to flat tow a Ford Escort (auto trans) behind a motorhome. Can this safely be done without torching the transmission? I know that certain makes and models are ok with this, what about an Escort?
Thanks in advance...........
7423 is offline   Reply With Quote
Old 06-23-2010, 08:10 AM   #2
Eddies66
Eddies66's Avatar
Liked 881 Times in 452 Posts
Default Re: OEM FWD auto trans question for the tranny guys
With the automatic you have to get an aftermarket pump to circulate transmission fluid through the trasmission when you are towing. More information on the lube pumps are found here:
http://www.remcotowing.com/lube_pump.php
You can order them through camping world or maybe other online sources. Call remco and find out what pump you need.
When you're set up,you just have to connect the car with the tow bars, plug it in, keep the ignition on run so the steering wheel is not locked, and gear selection lever in Neutral. I also used magnetic tow lights on that car but you can wire in the factory brake and turn lights also.
Eddies66 is offline   Reply With Quote
Old 06-23-2010, 08:13 AM   #3
jmcarter
jmcarter's Avatar
Liked 3,174 Times in 971 Posts
Is there a link that provides which vehicles can be towed without using the pumps to circulate the trans fluid?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 06-23-2010, 08:23 AM   #4
SSDiv6
Liked 1,580 Times in 582 Posts
Jim, they have an online chart:
http://www.remcotowing.com/vehicles
Old 06-23-2010, 09:16 AM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Try this link
http://www.motorhomemagazine.com/dinghytowingguide/
ss3011 is online now   Reply With Quote
