#11 |
Liked 67 Times in 30 Posts
The formula above is for radial tires, bias ply tires will grow, each manufacturer can
tell you approx how much at a given speed for any size tire. Like Alan stated each car can vary in how much flash it will take to get it moving and how it will lock up on the big end will depend on how much power and powerband width are available. Most of the converter companies can get you really close if you give them accurate info for hp, tq, weight,gearing and rpm potential. one other variable is where you race sea level will differ greatly from altitude and so on. trial and error!!!! just my .02$
Ron Mattson 5015 STK |
#12 |
I could be wrong, but if you record the engine RPM, and record the driveshaft RPM, assuming your in high gear and it's a 1:1 ratio, then the difference would be the converter slippage.
Fred Dempsey G/S, H/S, I/S, D/SA |
#13 |
Liked 685 Times in 204 Posts
In my SS car, according to the Racepak, 5% on a good run, 6% in poor air. Dyno
#14 |
Liked 51 Times in 12 Posts
Dyno
My race Pak is showing similar like 1 or 2% Just curious how you calculate the percentage of slip. Just curious for comparision sake Thanks Don |
#15 |
Liked 704 Times in 281 Posts
Using my ultimate 2 tach I came in at 3.5%.454 390 HP SS car
#16 |
Liked 20 Times in 12 Posts
#17 | |
Robert |
#18 |
Don, it will show in the Engine/DS ratio on your Racepak data. Check it at the end of the run.
#19 |
Liked 972 Times in 309 Posts
No secret Mike Munsinger is the man for torque convertors.
#20 |
Thanks Dyno
When I was looking at the Engine/DS ratio it is 1.073 I had assumed that was 7.3% slippage. However when I did the math Engine RPM 6134 D/S RPM 5715 I came up with 6.9%. Not trying to split hairs here just trying to understand the math. Thanks Again Don Turk |
