Old 06-05-2010, 05:50 PM   #1
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default battery location
so, according to the rule book (nhra), i need the battery in the "stock" location.
well, on this american i'm building, the stock location for a 6 cyl is on the LH side and a V-8 is on the RH side....
do i have a choice?
(it'll be a V-8...)
if so, does it have to be a factory tray?
honestly, i'd rather build a good one rather than use the oem one...
Old 06-05-2010, 05:55 PM   #2
Default Re: battery location
I've been told it must be in the stock location for the combination being run.
I'd guess, just a guess mind you, that the stock tray must be used, I don't remember ever seeing an aftermarket tray in the stock location on a stocker.
Ask Gracia or Bachelder, and get it in writing, do it by email if you like, and keep a copy with the car. You can use a heavy duty hold down, and so long as you do that, I'd say the stock tray will be sufficient.
Old 06-06-2010, 12:59 AM   #3
The original plastic battery tray in my Mustang was deteriorated beyond use. I fabricated a sturdier one out of aluminum .
The car has been through four teardowns and no one has ever said a word about it.
Just do it!
That goes the same for right side /left side. No one knows, no one cares on a 68 Rambler.
Old 06-06-2010, 06:20 AM   #4
Dragsinger
Liked 99 Times in 60 Posts
you would be fine to buy a replacement (steel, universal, battery tray from a parts store) and fab up a heavy duty hold down. That is completely acceptable.
Old 06-06-2010, 07:15 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Tom -
95% of the tech people will not know what is correct for your car, so you could do either and nobody would care. However, you will be better off with it in the correct V8 location to help balance the weight distribution of the front.
Old 06-06-2010, 08:48 AM   #6
Tom keedle
Tom keedle's Avatar
Tom -
as the engine is offset to the right (that's where amc put 'em, don't blame me ), i honestly don't know WHICH side would be best,particularly with the "tiny" driver (me).
as far as a tech guy knowing which side is which, they probably do now....
Old 06-06-2010, 09:45 AM   #7
Most, but not all cars have the battery mounted on the same side as the starter, and most good tech people know that.
That being said, I'm sure you can probably get away with fabricating a battery mount for it. I'd bet the worst that would happen is you'd be told to "fix it before you bring it back" if you found a tech guy who didn't like it.
Old 06-06-2010, 11:27 AM   #8
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Just put it on the passenger side,as in all V-8 locations.There is plenty of room to fit a tray
on the passenger side.Make sure to use the correct diameter hold down rods.My outside rod is a bit of a tight squeeze.When you install the trsy move it in a bit to have enough room to fit the hold down properly.
Former NHRA #1945
Former IHRA #1945
T/SA
