Old 05-29-2010, 09:37 PM   #11
art leong
Default Re: Intake manifold heat?
The material shown in the above link is phenolic laminate material.
It looked and felt like teflon to me. The one the sold me was white not blue.
It doesn't seem to work. I'll know for sure tomorrow.
Art Leong 2095 SS
Old 05-29-2010, 09:51 PM   #12
SSDiv6
It does not look like Teflon. Take the temp readings and post them.
Old 05-29-2010, 09:58 PM   #13
art leong
After a few of minutes at idle the intake runners were 105 degrees the head next to the intake manifold was 108. As the head got hotter the runners the runners got hotter to.
I didn't have the temp gun before but I think the runners stayed cooler longer, till they eventually heat soaked.
Art Leong 2095 SS
Old 05-29-2010, 10:12 PM   #14
SSDiv6
It may be too thin; the spacer looks more for a street/OEM application and it may need to be thicker for your application.
Just make your own heat spacer from a thick sheet of Black Nylon 66.
Old 05-29-2010, 10:39 PM   #15
art leong
The spacer is about .300 thick. How thick is the Black Nylon 66?
Art Leong 2095 SS
Old 05-29-2010, 10:46 PM   #16
SSDiv6
It's available in many thicknesses.
http://tridentplastics.thomasnet.com...eet?&forward=1
Old 05-30-2010, 07:52 PM   #17
Redlight
Thinking out loud:
Timing ?
Reversion?
Redlight is offline   Reply With Quote
Old 05-30-2010, 09:11 PM   #18
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Hey Art, in your class are you allowed coatings ?
Ive got some waterbased ceramic that is a heat dissapation coating, stuff works great. Ive got about a half gallon of the goo left, coating the intake inside and out I can almost guarentee a big heat soak drop......problem is once it does the stuff works the other way around and will hold it in, but it takes a lot longer ? Why kill the water passage ?
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 05-30-2010, 10:20 PM   #19
larry dowty
Liked 11 Times in 4 Posts
GOLD my wife is always cold when i am HOT it must be the gold ring
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 05-31-2010, 09:49 AM   #20
art leong
Originally Posted by Redlight View Post
Thinking out loud:
Timing ?
Reversion?
Pulled the motor to check the bearings. didn't mess with the timing belt at all.
Timing light is in the trailer. I'll go get it on Tuesday and double check it but it starts easy and idles great.
As far as reversion goes. This is a different cam (much bigger) than last year. I haven't paid attention to the manifold heat this year. Each time out I've been heating the engine, to allow heat soaking. I'm finally going to a track without eyes. So I want to know what I can pick up with a cold intake.
Took a leakdown to see if I had some bent intake valves It was 3 to 5 percent (not bad for gasported pistons).
This is the motor that I had asked about the compression pressure before It is 300 pounds. I worried myself sick about it. But have just learned to live with it as a quirk with the 4 valve setup.
Art Leong 2095 SS
