Just wondering where you guys are getting and using for air valves when running tubeless radial slicks? I've got a set that would be usable on the front tires but I thought there was a beefier style commonly used for the drag slicks?
Dion Hildebrandt 6009 STK H/SA |
Liked 60 Times in 12 Posts
Same as these.
http://www.jegs.com/i/Weld-Racing/92...ductId=1231910 Then get as bottle of Dawn dishwashing liquid and paint the insides of your new tires with 2 coats, let em dry , and you're good to go.
2894 STK |
whats with the soap a 'membrane' of sorts? the link for the stems are the ones I have ,I just wasnt sure if they were the correct ones
A good deal of slicks will seep air thru the side walls usually. That just seals the sidewalls and keeps you happier !
2894 STK |
Kenny, took your advice & it works. Painted inside heavy with a paint brush. Let them dry a day and gave them a second coat. No leaks.
Bobby & Norene Zlatkin L/SA |
Liked 16 Times in 11 Posts
Summit has 45deg bolt in valves.
Bob Pagano A/SA |
