Old 03-26-2010, 09:18 PM   #1
VORTECPRO
Default Turbo 250 or 350
In the process of building a 68 chevelle 396/325 for G/SA. My first question is how much quicker is a metric 200 than a light weight turbo 350. Has anyone kept records on 8 inch torque converter weights minus fluids? Is there anyone out there that has raced this combination or has been next to one of these cars and can recall 60 ft times, any information would be helpful, thanks Mark
VORTECPRO is offline   Reply With Quote
Old 03-26-2010, 09:50 PM   #2
Liked 1,780 Times in 405 Posts
Default Re: Turbo 250 or 350
A 250 is the same basic transmission as a 350, except the 250 uses a band for second gear, instead of clutches and a sprag. I don't think the second gear band in a 250 will hold. And besides, it wouldn't be any quicker.
Are you sure you don't want to compare a 200 Metric to a 350?
Old 03-27-2010, 06:05 AM   #3
VORTECPRO
Thanks for the correction, the metric 200 is the trans I was thinking about. The thread has been edited.
Old 03-27-2010, 06:44 AM   #4
Robert Swartz
Robert Swartz's Avatar
This is just a "FWIT" answer. I really thought I wanted a Metric 200 for my project. There are a lot them in stockers now.
Someone might sway my opinion on this but, from talking with a couple different racers, they may not be as great as they seem. They have been described to me as being "fragile". As in requiring the transmission to need to be freshend between 50-150 passes. Here again, take it as a comment, I'm passing along second hand information.
I'm going with the t-350 on my crate motor project. Down the road, once I get the car running and established. I may look at a metric-200 again.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 03-27-2010, 07:51 AM   #5
If you want to run a 200, there are only a few people who build them well enough. Two of them I am familiar with are Scott McClay and Thomas Arnett. There are others, but those two guys build a 200 that will hold up to MOST Stock Eliminator cars. And yes, they are a little faster than a 350, even a really light 350.
Old 03-27-2010, 09:01 AM   #6
FED 387
Liked 329 Times in 177 Posts
It is my understanding that a 350 has almost the same external dimensions as the Glide, uses 15-17 more HP just to turn the transmission than a Glide and a 350 weighs a little bit more than a glide(maybe 15-20 pounds) and you cannot use a 350 with an engine that revs over like 7000 rpm( they want to self destruct). BUT you do get that extra gear in there!!!
Now a Metric 200 has the lite weight of a Glide, you can spin the engine well over 7000 RPM like a glide , it takes about the same amount of HP to turn the trans as a Glide AND you get the benefit of the extra gear. Its weak point is UNLESS it is really beefed up it will self destruct on its own at low RPM , in a heavy vehicle, in normal everyday street use that's why GM stopped using them.
Unless you are looking to extract the last thousandth out of your car--you do not either want the hassle of the maintainence or have the ability to do trans work you might be better to go with a 350 til you hit that plateau in your level of performance where you feel you could use the extra gear that both transmissions over---Comp 387
Old 03-27-2010, 09:12 AM   #7
Bill Grubbs
Liked 564 Times in 66 Posts
We routinely hit 7800-8200 with a TuboAction T-350, and have not had any problems in 8+ years of using them. We do however freshen them up every 200-300 runs.
Bill Grubbs is offline   Reply With Quote
Old 03-27-2010, 09:29 AM   #8
FED 387
Bill---every one has their success story---yours is one of them---I'm by no means any kind of an expert on 200 vs 350 transmissions---Only that not very many if any of the Comp guys are using a 350----lotsa proflites /glides and some 200 but only ony guy I know of is/has been using a 350 and he is doing the R&D as a test vehicle for a racing trans company we all know---Comp 387
Old 03-27-2010, 10:40 AM   #9
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
I have been very pleased with my TurboAction 200. Paul, in my opinion, is the man for those !
2894 STK
Old 03-27-2010, 12:04 PM   #10
Nope, a 350 will not explode at RPM in excess of 7000. I've built them since 1984, and never seen one explode, and that includes a lot of race transmissions.
Nothing explodes like a TorqueFlite!!!!!!!
