Old 03-15-2010, 09:21 PM   #1
Dennis Paz
Liked 5 Times in 3 Posts
Default M/t radial problem
I have a set of the 12.25 w radials with maybe 25 passes and all of a sudden car is way unstable on top end, put old bias plys back on and car is perfect. What gives??
Dennis Paz is offline   Reply With Quote
Old 03-15-2010, 11:38 PM   #2
partsbob67
Liked 79 Times in 11 Posts
Default Re: M/t radial problem
that elky is too fast now!!!!
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 03-16-2010, 12:25 AM   #3
Dennis Paz
TOO FAST?
Gotta say I am plesantly surprised especially after the 3 tenth chop.
These tires S U C K! ole worn out bias ply hoosiers way more stable on top end.
Old 03-16-2010, 08:57 AM   #4
Bill Grubbs
Liked 564 Times in 66 Posts
Have you talked with Carl Robinson @ M/T?
Bill Grubbs is offline   Reply With Quote
Old 03-16-2010, 09:24 AM   #5
mjacquesjr
have you rechecked the balance
mjacquesjr is offline   Reply With Quote
Old 03-16-2010, 09:28 AM   #6
Dennis Paz
Bill
I dont know anyone at M/T, Is Carl in so/cal?
Not a balance problem as car is smooth, feels like running on flats with 20 psi.
Old 03-16-2010, 09:52 AM   #7
Ed Wright
Ed Wright's Avatar
One thing I have found about radials, they tend to do that if the wheels aren't wide enough.
Mine totally stopped doing that after I learned to use wheels wider than the tread area of the tires. I put my 9" radials on 10" wheels, and my 10.5" on 12" wheels. Made a whole new car out of mine. I can run more air, it hooks harder and no more wobble.
Ed Wright 4156 SS/JA
Old 03-16-2010, 11:47 AM   #8
Marc LaBrecque
Liked 432 Times in 115 Posts
Smile Re: M/t radial problem
I've run these tires on my S/Stocker for several years with great sucsess . At first I ran them with a 12" rim and had some wobble . Since going with a 14" rim I run approx 18lbs of tire pressure and I do have a sway bar My truck is absolutley stable no shake . Also about 8-10th quicker and have consistantley put over a hundred runs on them . As in any radial tire make sure all suspinsion is tight .
Marc
Marc LaBrecque is online now   Reply With Quote
Old 03-16-2010, 11:55 AM   #9
buzzinhalfdozen
Liked 11 Times in 8 Posts
I agree the wheel width does seem to have a distinct effect on these tires, wider wheel is preferrable. Joe
Joe Buchanan SS/BX 3117
Old 03-16-2010, 12:06 PM   #10
Bill Grubbs
Bill
Carl...is...M/T.
Call Them and ask to talk to him.
Bill
