#11 |
How does the information from a compression test compare to a leak down test? Which provides the best info on engine condition?
With leak down you can hear the air leaking and determine if the probelm is rings, exhaust or intake valves. In stock what are good leak down numbers, when is it time to re ring or do the valves?
Cam Chowen 6067 1994 Camaro C/S |
#12 |
Has any one ever started an engine while the compression gauge was screwed into a spark plug hole?.....thats an eye opener.
67 Ford Fairlane F/SA 749 |
#13 |
Liked 165 Times in 59 Posts
yes,,,,it gives you real time mesurements while running,,but the the true test is in the first 1-2 revolutions of the engine crank,,if it pops up to top presure during crank you know you are in good shape with the compression gmonde
#14 | |
Engine leak test 101 http://www.carcraft.com/techarticles...ter/index.html
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
#15 | |
Liked 49 Times in 15 Posts
Leak down tests should be used similar to compression tests. All cylinders should test equal. Having said that, there are many fast stocker motors that leak close to 10%. With the metric rings and ported spacers many engine builders are using, static ring seal is very low. But under combustion pressure the rings seal fine. If your trying to diagnose a ring problem, careful examination of cylinder wall and ring wear is a better choice. Perhaps the best answer to your question would be to know what your motor leaked when it was new. You could then check it later for loss and variation.
Dean Feiock -- Stock 5002 |
