Old 03-13-2010, 11:59 AM   #11
west coast
Liked 227 Times in 74 Posts
Default Re: Big silly rookie question
Print out a tech card off NHRA site must login in to get to it you can fill out all the info online. In stock there are quit a bit of other info that is needed to be filled in that a normal racer doesnt fill out like Adv HP, Adj HP, Head#, Intake #, Carb#, all this you want to make sure is right for your combo make and year. Just because your car is a certain year does not mean the Numbers on your heads and intake are going to be right for what are in the guide lines for your car, mine did not match had to claim a differant year because of intake numbers and everthing else matched up to the year I was changing it to. Drooze said it very well to his experance tell them you are new to stock they are very helpfull. If you allready have question Email Dave at Div 6 ahead of time he response very quickly. See ya in Boise.
west coast is offline   Reply With Quote
Old 03-13-2010, 08:12 PM   #12
Joe Toller
Liked 9 Times in 9 Posts
Tha nks for all the pointers and info, it really helps alot!
Old 03-13-2010, 08:38 PM   #13
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Is it the 135 cid motor in your car?
Old 03-13-2010, 11:38 PM   #14
Joe Toller
Yes, 135 cid turbo
Old 03-15-2010, 10:35 PM   #15
Mike Carr
Mike Carr's Avatar
The Sedan 4 door breaks at 16.50, making it a natural BF/S, meaning it can also run A and C, with weight adjustments. The Sedan 4 door SE, breaks at 16.86, and will fit the same three classes. It's factory rating is 146, with an NHRA rating is 160. So you will multiply 160 x the class weight break, add 170, and will give you the minimum weight for each class, as follows.
AF/S 13 x 160 + 170 = 2,250 pounds minimum weight (seems highly unlikely that your car could get to the class' minimum weight. Class Index is 13.85 seconds.
BF/S 16 x 160 + 170 = 2,730 min wt. Class Index is 14.65 sec. This is the closest weight to the cars natural factory shipping weight.
CF/S 17.5 x 160 + 170 = 2,970 min wt. Class Index is 15.15 sec.
Hope this helps.
Old 03-16-2010, 07:05 PM   #16
Joe Toller
Thank you very much for that info. I was wondering what class I'd be in. Think I need to see what it'll do, and I'm betting I'm closer to CF weight because this thing is loaded to the nines. I'll go get it on a scale this weekend and go from there. Thanks!
I also have an 86 Lebaron GTS, and it's manual windows, non-tilt etc, probably would be a great car too, and lighter, and I could always swap stuff over since the mechanicals are the exact same. Guess I'd better get to work!
Thanks again!
Old 03-16-2010, 07:49 PM   #17
Mike Carr
Mike Carr's Avatar
86 Lebaron GTS 4 door with the turbo 135?
Old 03-16-2010, 08:22 PM   #18
Mike Carr
Mike Carr's Avatar
All versions listed for the Lebaron in 1986 (LEBARON, Sedan 2 Dr, 2588, Convertible, Town & Country SW 4 Dr, and GTS 4 Dr, all have weight breaks betwen 16.10 and 17.16, and all fall as a natural BF/S, and all can run A and C also. 146 factory HP rating, but NHRA rates this year motor, in this year car(s) at 155. Factory Shipping weights run from 2,495 pounds up to 2,685, depending on body type.
AF/S 155 x 13 + 170 = 2,185 pounds, 13.85 Class Index
BF/S 155 x 16 + 170 = 2,650 pounds, 14.65 Class Index
CF/S 155 x 17.5 + 170 = 2,883 pounds, 15.15 Index
Old 03-17-2010, 07:18 AM   #19
Hagen Gary
Liked 34 Times in 10 Posts
Originally Posted by Mike Carr View Post
1987 Dodge Lancer is in there. I think the turbo version would be the 135 cid, 146 factory, 160 NHRA-rated motor.
Wow, I might be showing my age or my ignorance, but when I think "lancer turbo".. I'm not thinking about no dodge.
Hagen Gary is offline   Reply With Quote
Old 03-17-2010, 08:09 AM   #20
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Alright Ive got the CAPITAL Stupid question here.....
Does the car HAVE to run in the F classes ? I just reread the rules and while the F Classes I dont see anything that keeps them in there specifically ? How wrong am I on this ? I entered the Pacifica as a Q/SA was it supposed to (i.e. HAD to Go in as CF/SA ?., 17.98lb/hp)
My understanding (and please I just came up with this on my "own" from reading the rule, is that it CAN be entered in the F classes if it is FWD, but nowhere in the rulebook I see does it say it HAS to ?)
Cheers
Im dying to hear an answer on this.
Chris
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
