#21 |
hey drooze keep up the good work on pop's car can't wait to see it run and see the numbers.on the other question in stock if i'm not mistaken you can use the same amount of forward speeds that the car came with from the factory,that being said why go to a 4speed when you could use a 5 or 6 speed and go to a deeper low gear set with not as much rpm drop on the gear changes to keep the motor in its powerband easier and make it more efficient.
#22 | |
Thanks
Well......why not 6 .... hmmm..... I guess if the motor has the "umph" why not go with a wider ratio and 4 , less shifts, less potential for error, I have yet to see a really fast and consistent 6 speed out there (dosent mean there arent , I just havent seen it) That being said, 1-4 seems ok...and the ratios available for the T56 seem nice for that (the 1-4) cant see using .83 in a drag car ever ? (could be 110% wrong though) Thats why Im asking.... Cheers Chris Quote:
#23 |
in a 5 speed aplication you could go as low as you wanted as in a 3.50 low gear and evenly space out the rest of the ratio's to help with the rpm drop off on the gear changes.in the 4 speed it would be like a 3.0-3.2 low gear an then second would be in the 2.0-1.9 range and there would be a bigger drop off than there would with a 5 speed.i do know that a ss/ah stick team tested with 4speeds and 5speeds and these were the results that they came up with,the car was faster with the 5 speed and the powerband was more managable because it didn't have to be as wide as with the 4speed.
#24 | |
Liked 8 Times in 7 Posts
oh, i'm not saying that it's the desirable trans BUT i have it and it won't be going on the "good" engine... i think i figured out once upon a time if this car ran a 14 flat up here, it's be a record run... btw, the rear is an 8 3/4 mopar w/4.57 gears (8.5x26" tall tires, ain't room for anything taller or wider) |
#25 | |
the biggest question is can i still shift? not the trans, ...me. i AM getting older...but i have NO desire to run an auto....i'm doing this for fun and, honestly, if it ends up being another "job",i'll run brackets (we've got a stick series out here... |
#26 |
How come manual trans threads draw so many opinions ? With all this ratio talk how would a 2 spd ever get downtrack? ...Thanx Trevor
#27 |
Liked 520 Times in 132 Posts
Save up buy a Jerico and a soft-lok clutch(Hyatt,Mcleod,Advanced,Ram, etc) and you will be happy. Ed
#28 |
I would disagree with Mark that a stick won't work well because of the weight and low RPM of the car. It's evident in the post he's behind the times and clutch and flywheel technology have come a long way since he had the Pontiac.
On the other hand, I think if one can't afford to do it right (trans, clutch package), then you would save yourself a lot of expensive aggravation if you stayed away from a stick.
Jeff Lee 7494 D/S '70 AMX |
#29 | |
Liked 5,147 Times in 1,964 Posts
Only reason I'm behind the times ,is because I choose to be ,especially with that combination.
#30 |
Liked 364 Times in 138 Posts
Trevor, you have a PM
Dave Turner SS/GT #1153 |
