Old 01-26-2010, 10:08 PM   #1
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default What I want to do...what I should do...what I can do....
BAH....another day behind....theyll only have 2 days for the FI install....
But the car required some surgery today for an unplanned event....gotta love Roush........(they built the "chassis" well the BIW of these)
Im wrapping into the brake lines, Im torn between riunning a hard line to a T on the Dif itself and to each caliper with 1 braided line to account for "swing" if the diff
Or.....running a T on the Chassis and a flexible line to each.....? (cant think of why Id do this)
Or running....? Bah....so many choices, litteraly, any suggestions of things youve done, seen work/not work......in my mind the less ("hose") braided or not the better.
Id also like to keep the lines equidistant obviously as well....
Anyone (pics also greatly appreciated....my mind is melting)
Chris "drooze" Wertman is offline   Reply With Quote
Old 01-27-2010, 08:20 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: What I want to do...what I should do...what I can do....
I've always ran the rear line to a bulkhead fitting on the chassis, then a flex line down to a bulkhead T at the diff.Then run lines to each caliper. Joe
Joe Buchanan SS/BX 3117
Old 01-27-2010, 11:03 AM   #3
Rod Greene
Liked 242 Times in 81 Posts
I have always run hard line on the chassis T it and then run flex line down to the calipers. If you ever have to pull the complete rear end you just hang the calipers off the car and leave the brake system intact.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
