Old 12-21-2009, 10:41 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Question Stud Girdles / Stud Alignment
Is it typical when installing a stud girdle set that the rockers are out of location by 0.100" or so center to center? I just bought a set of the Jegs house brand for small block chev and they will tighten down, but they are moving the studs around more than I figured they would.
Thanks,
Chad
Chad E532 is online now   Reply With Quote
Old 12-21-2009, 11:35 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Stud Girdles / Stud Alignment
Wow , .100 seems like alot, sometimes really cheapo rocker studs have alot of runout in them. ARP studs run real true.
Old 12-22-2009, 12:18 AM   #3
Dennis Paz
Liked 5 Times in 3 Posts
what heads/what motor?
Dennis Paz is offline   Reply With Quote
Old 12-22-2009, 09:46 AM   #4
Chad E532
Chad E532's Avatar
AFR 195 eliminator heads with ARP studs. The tech guy at Jegs recommended that I return their house brand set and go to the AFR since the machining maybe slightly different. That is what I get for trying to save a little money and go the cheaper route.
Thanks,
Chad
Old 12-22-2009, 10:35 AM   #5
Leon Rennebaum
I believe that the valves in AFR heads are relocated to provide clearance for the intake ports so that it is imperative that the stud girdle be machined for the particular AFR head. I would suggest contacting AFR, give them the serial numbers from the head and let them tell you which stud girdle would be the correct fit!!
Leon Rennebaum is offline   Reply With Quote
Old 12-22-2009, 10:44 AM   #6
Dennis Paz
ONLY girdle that will work is AFR girdle
I just whent through the same thing with there eliminator head.
Old 12-22-2009, 01:35 PM   #7
Rob Petrie E395
Liked 216 Times in 77 Posts
I run both the AFR 210cc and the 227cc heads. On the 210cc heads I use a regular Moroso SBC stud girdle and ARP studs with no problem what so ever and everything lines up perfect. Now on the 227 they relocate the valve to clear the intake port and you have to run their girdle as it is machined correctly and offset rockers or run shaft rockers. I am pretty sure the 195cc heads use standard valve locations, I would think its either a machining problem with the jegs girdle or studs that dont run true.
Old 12-23-2009, 07:23 AM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 320 Times in 109 Posts
They may have 40\60 stud/valve spacing like the 867 pontiac heads(for SBC) If thats the case you may find some used ones floating around,but to get new you would have to buy from Crane?,Comp, Jomar,AFR
Mike Taylor3601
Mike Taylor 3601 is online now   Reply With Quote
