Old 12-23-2009, 05:49 AM   #161
Paul Ceasrine
Liked 10 Times in 10 Posts
Default Re: '66 Dodge D-Dart at Mecum auction
Bill,
If I did my math correctly, doesn't 4-head bolts x (2) Vortechs = BOOM!!
Paul
Old 12-24-2009, 12:05 AM   #162
bill dedman
Liked 6 Times in 4 Posts
Probably....
We may find out........ LOL!
That's one way to get rid of this P.O.S. time-bomb short block...
Bill
bill dedman is offline   Reply With Quote
Old 12-24-2009, 07:22 AM   #163
Paul Ceasrine
Bill,
If you want a wild holeshot ride, I can go back to my fathers old machine shop and go in the basement, and pull out the de-stroked 340,
305 engine with 12.5 - 1 Arias pistons, and Kenyon-prepped heads.
Now, that would be one wild launch in that A-Body. Unfortunately, the Vortechs will not be "Required Components", unless you like
molten pistons
Paul
Old 12-25-2009, 07:22 AM   #164
Paul Ceasrine
Alan,
if you check out the "Mods for Mopar 273" article, Feb 66' Hot Rod,
with Tom Hoover and Mike Buckle (of the Ramchargers), you can see the first free-breathing intake manifold. A standard 273 cast iron intake, with the carburetor butterfly openings cut-out to 1 11/16" (primary and secondary) for the first Holley carb to be mounted on the intake, during
the early stages of the D-Dart. The first carb used was a 4160 #3116
600 cfm, off the 65' Race Hemi's.
Paul
Old 12-26-2009, 05:12 PM   #165
bill dedman
Paul,
Billy Nees gets his satifaction from turning an 18-second street slug into a 14-second race car, utilizing only class-legal methods. I think I must get the same kind of satisfaction out of seeing how much horsepower I can wring out of this (almost) stock, OEM shortblock (cam change, only) with a superchagrer and a 750 Holley, without damaging the engine.
I think I'm already walking a VERY thin line, now, and any more positive additiions to the B.M.E.P will likely push her over the edge....
Guess I'll work on the chassis for a while and try to take some weight off the front of the car.
I need this thing to hook up... Workin' on that.
Bill
Old 12-27-2009, 06:48 AM   #166
Paul Ceasrine
Bill,
Are you going 'Old-School' on the front-end lightening?
You know; 6-cylinder torsion bars, V-100 shocks, truck-mounted battery,
drum brakes, remove the sway (anti-roll) bar.
Or modified 'Old-School', plastic front bumper support brackets
Now who would do that? Wouldn't that be cheating in Stock Eliminator
Paul
Old 12-27-2009, 05:19 PM   #167
ddartdude
Paul,
I have first dibbs on the destrokes 340........................
The intake in that article was developed during the 65 race season. The carb adapters that are on the D/Dart engines were machined in house. You can see along the sides that they were cut out on a band saw.
Got a question on Kenyon. As advertised on the front fender of "The Politician" the heads on the car were from Kenyon. Who was Kenyon and where were they located? I was in grade school in the Cleveland area when the D/Darts were produce so I'm sort of lost here.
Alan
ddartdude is offline   Reply With Quote
Old 12-27-2009, 05:34 PM   #168
bill dedman
It doesn't matter because I'm not running this car in any class-legal configuration; Brackets, only.
Insofar as what I'v done, it's minimal. at best:
Things already done:
90-10 shocks in front / 50/50 shocks in back
it never had a sway (anti-roll) bar
The K-H, 4-piston caliper, disk-brakes are going to be retained
The 340 torsion bars will remain, for the moment (318 4-drs with A-C had 340 bars)
Spring clamps on the forward portion of the leaf springs
Air Bag on right rear spring for pre-load
Auburn limited-slip
4-degree pinion wedge for proper rear u-joint angle
removed the OEM, spring clamps for leaf separation on acceleration
2 BIG batteries in trunk, on right side, in the rear portion
A-C compressor, condenser, and lines removed; evaporator remains, for the moment
Adjustable pinion snubber
For next season:
fiberglass front bumper and hood (pin-on)
Replace heavy-*** carpet with light, no sound-deadener, carpet.
lightweight front bumper brackete
replace heavy-*** bench seat with one (1) D-100 (cargo van) bucket
install driveshaft loop
install 4.10 center section (3.55 has been in there, until now
install 9" X 28" M-T bias-ply slicks on new, 7"-wide, 28"-tall, Ansen Sprints
Hopefully, all that will improve the 60-footers .3..... (from 1.81, prior)
Talk's cheap; we'll see...
Bill
Old 12-27-2009, 05:40 PM   #169
bill dedman
post deleted; duplication.... sorry.
Bill
Old 12-28-2009, 06:26 AM   #170
Paul Ceasrine
Alan,
Kenyon Cylinder Heads
Fred Kenyon was the hot cylinder head guy for awhile in the mid-late 60's, and early 70's.. Trick-blending on the valve seat area, and flow improvements for the ports. Then RHS 'Racing Head Service' came into play, and kind of stole his thunder.
Kenyon Machine, still in business in San Diego. Alot of West Coast
Stockers and S/S guys used them. His cylinder heads were the hot ticket for 67'/68'.
I noticed in Mopar 273 article that one of the intakes (dual-quad) cut out the center section of the primary and secondary openings, and left the thin center-divider between the sections, shaped like the letter 'B' faced back-to-back. That's the way we cut-out our manifold, at first.
Paul
