Old 12-13-2009, 10:28 PM   #1
racerxo69
Default 55mm cam clearance
anyone know if a 3.5" stroke crank with 2.1 journals with manley aluminum rods would clear a 55mm cam.
racerxo69 is offline   Reply With Quote
Old 12-14-2009, 09:17 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 310 Times in 104 Posts
Default Re: 55mm cam clearance
You need to mock it up and check w/cam degreed,I say it will be close, if does touch I would notch rods w/flycutter on bridgeport style mill get one where it misses by .050'' then you can cut other 7 exactly the same.I always notch all 8 to keep weights equal for easier balancing and to eliminate chance of having rods in wrong cylinder if only notched for cylinders that hit. also if notching will get into bolt, torque rods before notching so bolt will match notch.Don't have base circle of cam reduced or you will lose one of the benifits of 55MM cam.
Mike Taylor 3601
